Building a hill...
Beynac
Building a hill...
Postby Beynac » Mon Apr 03, 2017 5:29 pm
Hi all and one,
this is my last idea of the day: building a small hill (diameter: 420mm). It's just the beginning. Pictures talk better than words.
All your constructive criticisms are welcome ! This is the first step:
HILL #1.jpg (127.22 KiB) Viewed 1162 times
HILL #2.jpg (124.12 KiB) Viewed 1162 times
I'm just a guy who wants to play with his toys. Image
Re: Building a hill...
Postby TimberSurf » Tue Apr 04, 2017 10:12 am
That's less of a hill and more of a mountain!
The sides are very steep, I would think it would be a rocky cliff rather than a grassy moll!
Beynac
Postby Beynac » Tue Apr 04, 2017 11:21 am
:lol: :lol: :lol:
luckymucklebackit
Postby luckymucklebackit » Tue Apr 04, 2017 12:30 pm
Ayers Rock???
Beynac
Postby Beynac » Tue Apr 04, 2017 2:53 pm
The second step has been delayed a little bit... :mrgreen:
Beynac
Postby Beynac » Wed Apr 05, 2017 8:45 pm
Done ! I'm very happy with the result. :D
It also needs some painting (what colour ?) and some grass (what kind of stuff ?).
HILL #3.jpg (306.39 KiB) Viewed 1066 times
To be continued...
Postby TimberSurf » Wed Apr 05, 2017 9:08 pm
Most mountains are grey! The grass should be white, as it would be snow! :D
But seriously......
Paint - depends on the look you are going for with the grass.
Grey - for rocky outcrops on steep sides {I think this is the case :) }
Brown - if you want that winter look of mud beneath rough grass
Green - for normal summer "I cant see the ground for the thick grass"
Grass
Grass mat - good for flat area's, would be difficult to fit on your mountain!
Flock - (died sawdust/rubber) basic cheap imitation grass
Static grass - Applied with an electrostatic charge to make it stick upright (plastic bottle dispenser or electronic gizmo) {can be applied without static, for rough/windswept area's}
bon chance mon ami
Beynac
Postby Beynac » Thu Apr 06, 2017 7:48 am
Merci mon ami. :D
Thanks. Can I use this kind of stuff: Javis Scenics scatter ?
Postby b308 » Thu Apr 06, 2017 8:01 am
Yes but bear in mind even grass tends to struggle to grow on vertical surfaces!
I would agree with TS, I recon you'd have nearly as much rock on show as grass, this sort or terrain...
https://www.visitscotland.com/cms-image ... ss?size=sm
Postby TimberSurf » Thu Apr 06, 2017 8:56 am
Beynac wrote:Merci mon ami. :D
absolument
Yes, by far the cheapest option. But just for fun, get a small pack of 4mm yellow "Static Grass" and try making some grass tufts :D
Example here viewtopic.php?f=16&t=27613&start=45#p625999
Starter kit http://www.hattons.co.uk/59996/Gaugemas ... etail.aspx or buy a static grass applicator ("Fly killer") on ebay
Beynac
Postby Beynac » Thu Apr 06, 2017 11:21 am
Thanks folks. All your answers and the links are very helpful.
The Gaugemaster Starter Kit is made by Noch. I can buy all Noch products directly from Noch in Germany.
Beynac
Postby Beynac » Thu Apr 06, 2017 1:07 pm
Another question: how many Javis Scenics scatter bags do I need for my small hill (diameter 420mm) ?
Postby TimberSurf » Thu Apr 06, 2017 1:22 pm
The coverage is a bit trial and error, but more importantly, a single colour will look too uniform, buy a few colours and mix it up around the hill and mix two colours for even better natural patchy look. Mother nature has more than just a few tins of paint!
Beynac
Postby Beynac » Thu Apr 06, 2017 5:47 pm
First coat of brown paint (I know it looks like a big chocolate cake :lol: ):
HILL #5.jpg (164.01 KiB) Viewed 1012 times
To be continued...
Beynac
Postby Beynac » Fri Apr 07, 2017 9:51 am
I found this very interesting thread: Types Of Senic Matieral. Very helpful.
Return to “Scenery”
