Noch Grass Mat Spring Meadow
Beynac
Postby Beynac » Wed Mar 29, 2017 8:11 am
Hello there !
I'm planning to use a Noch Grass Mat Spring Meadow for my layout. All your advices about it are welcome. Thanks in advance.
I'm just a guy who wants to play with his toys. Image
Re: Noch Grass Mat Spring Meadow
Postby b308 » Wed Mar 29, 2017 9:19 am
1. Make sure the board you are fixing it to is not completely flat, unless you are modelling a cricket pitch... It looks daft if laid on a flat surface.
2. I use slightly watered down PVA to glue grass mats down, the glue soaks into the backing at it means you can mould it to the contours more easily.
3. On it's own it looks a bit too "regular", you need to break it up with tufts of static grass to make it look a little wilder... Get hold of some decent photos of summer meadows and you'll see what i mean... Combining various types of grassmat can help as well...
As a good way of covering large areas grassmats are fine, though they do need some work to look realistic and not like a model...
Current layout, grassmat just laid, blending in to follow:
Previous layout after blending in:
Beynac
Postby Beynac » Wed Mar 29, 2017 11:35 am
Thanks. It's very helpful. You have a wonderful layout. Is there any thread about it ?
Postby b308 » Wed Mar 29, 2017 11:51 am
Yes, two, this is the completed layout:
viewtopic.php?f=22&t=48366
This is the new one:
viewtopic.php?f=44&t=50987&p=626505#p626505
Postby TimberSurf » Sat Apr 01, 2017 11:29 pm
Grass mats are great for large area's, meadows/fields/embankments etc, but for smaller areas you should look into "static grass", also good for 'adding" variation to grass mats as mentioned by b308
Return to “Scenery”
