I have a Train-Tech CL1 Motion sensing LED coach lighting strip that came with a 2nd hand loco.
The strip only lights the main seating area of my Hornby Class 121 not the end driving cabs so I want to try to add 2 extra LED's to the strip to light both cabs.
I have thought about cutting the strip into a couple of pieces (which I may still do) so it will go around the 2 full coach height, vertical screw coloumns that hold the body on (as the strip is rigid and over to one side of the roof rather than directly in the middle), but even so the LED's wouldn't reach the cabs thus the idea to add 2 more LED's to the strips.
Has anyone tried adding extra LED's to one of these strips?
It looks easy enough to solder extra LED's on but would the CR2032 light the 2 extra LED's? And would I need a resistor on each of the added LED's long leg?
(I only have 1K resistors at present)
Also as a side note... Has anyone tried installing directional lighting into this model?
It's a Hornby Class 121 Driving Motor Brake ' W55020 ' R2644 DCC ready (with a Lenz Standard+ decoder installed at the moment)
Updating coach interiors?
Re: Updating coach interiors?
105 interior respored to (as far as I can tell) 'as built' condition - https://www.flickr.com/photos/74009/8564801596
121 ditto - http://preserved.railcar.co.uk/Images/1 ... oxon-c.jpg (more photos on the same site)
4-wheelers - can you actually see through the windows ? Make it up, Hornby did !
No references for GWR interiors, sorry.
Sorry I should have mentioned the liveries
GREEN Bachmann Class 105 DMU with speed whiskers. It's packed away at the moment but I think the interior is plain brown.
CHOCOLATE AND CREAM Airfix Autocoach with a plain cream coloured interior
CHOCOLATE AND CREAM Hornby Class 121 Bubblecar with a plain dark blue interior (Train tech CL1 light strip in roof which really shows up the plain, emptyness of the model)
CHOCOLATE AND CREAM Bachmann collett coach (corridor version) with a lightish brown interior
CHOCOLATE AND CREAM Hornby 4 wheel coaches in with no internal seating so these will have to be scratch built but I am not sure of floor / seating colours etc.
I say chocolate and cream as some are BR rather than GWR.
More than likely once lighting has been added.
stuartp wrote:4-wheelers - can you actually see through the windows ? Make it up, Hornby did !
The overhaul has been completed and can be seen here - viewtopic.php?f=1&t=48416&p=593885#p593883
Re: Updating coach interiors? - Airfix Autocoach
Does anyone know the Hornby metal replacement wheel sets for an Airfix Autocoach per chance?
I need metal ones so I can take power from the track to light the interior.
Also does anyone have any pictures of internal details like seat / floor colours on the prototype? Not the blue BR version.
- flying scotsman123
End2end wrote:Also does anyone have any pictures of internal details like seat / floor colours on the prototype? Not the blue BR version.
There's some useful internal photos of the one at Didcot here Which is more or less the type the Airfix model claims to represent.
Any 14mm metal disk coach wheel sets should be fine that have the same length axles as those you remove.
Thanks members.
I do have a couple of Hornby R8218 14.1mm wheel sets (although I'd need 2 more). I'll give them a go to see if they fit.
