Earth
Monty
Earth
Postby Monty » Mon Feb 13, 2012 2:00 pm
Can anyone recommend an earth coloured paint to apply beofre static grass etc?
Monty
Essex2Visuvesi
Re: Earth
Postby Essex2Visuvesi » Mon Feb 13, 2012 2:04 pm
There are hundreds of different coloured dirts varying from red to brown and other colours as well.
Take a look at pictures from where you are modelling and go from there.... Humbrol Matt Dark Earth is quite a good start tho but expensive if you want to cover a large area.
Tester pots from **Insert favorite DIY store here** make a more ecconomical option... and the paint can be watered down to give even more coverage
Proud member of the OAM
Monty
Re: Earth
Postby Monty » Mon Feb 13, 2012 8:16 pm
Of course, I hadn't thought of the many, many possible colours before I posted that question. (Note to self - occasionally turn brain on.)
Monty
fratton
Re: Earth
Postby fratton » Tue Feb 14, 2012 2:01 am
i just went for brown poster paint cheap and abundently availible,,,,
Hulldude15
Re: Earth
Postby Hulldude15 » Mon Feb 27, 2012 9:04 pm
I use a mix of brown and green poster paint and it looks quite effective if you get it far enough away from the horrible generic colours of poster paint.
flying scotsman123
Re: Earth
Postby flying scotsman123 » Wed Feb 29, 2012 7:18 pm
exactly what i did, although if doing green for grass, be careful. i mixed mine in a shadowy area of the loft, i started painting it it and it came out bright green :shock:
Re: Earth
Postby b308 » Thu Mar 01, 2012 9:12 am
fratton wrote:i just went for brown poster paint
So do I!
Its worth doing as well, same as mixing some colour into plaster/filler before applying to the layout... At least you don't get white bits if it gets chipped! One of those simple tips that tend to get ignored... Well done, Monty, for raising it!
Return to “Scenery”
