What is the best way to stick down grass mat
royeslough
Postby royeslough » Wed Feb 08, 2012 10:08 pm
Hi,
I have some tasma grass mat which I have been told to be careful in sticking down to avoid wrinkles.
It appears to have a paper backing, so I intended to use slightly watered PVA. This would give some time to adjust and smoothout.
(BTW IT is a flat baseboard)
Any better suggestions or is PVA the best way to go?
Essex2Visuvesi
Re: What is the best way to stick down grass mat
Postby Essex2Visuvesi » Thu Feb 09, 2012 6:45 am
wallpaper paste works quite well... paste the back and then WAIT a few mins to allow the paper to absorb the paste. This will help prevent wrinkles as the paper is already expanded.
Or you can use spray mount adhesive glue
Proud member of the OAM
royeslough
Postby royeslough » Thu Feb 09, 2012 9:02 am
Ok I will try a Sample with PVA and wallpaper paste and report back
Essex2Visuvesi
Postby Essex2Visuvesi » Thu Feb 09, 2012 9:13 am
royeslough wrote:Ok I will try a Sample with PVA and wallpaper paste and report back
Always good to experiment away from the main layout lol :)
Never tried that brand of grass matting but Wallpaper paste works well for noch and gaugemaster mats
flying scotsman123
Postby flying scotsman123 » Thu Feb 09, 2012 7:08 pm
Essex2Visuvesi wrote:Or you can use spray mount adhesive glue
this stuff costs a fortune if you're planning to cover a large area, for other uses, i use watered down pva in an empty spray :P
Postby b308 » Thu Feb 09, 2012 7:25 pm
I'm another that uses PVA...
HARRYMALLARD
Postby HARRYMALLARD » Fri Feb 10, 2012 12:06 pm
Same here :D
My layouts:
Clicky here --> Image
Gasworks Lane micro layout
flying scotsman123
Postby flying scotsman123 » Fri Feb 10, 2012 8:25 pm
without PVA, there is caos 8)
Tiago&Nats
Postby Tiago&Nats » Fri Feb 10, 2012 8:55 pm
how about spray adhesive glue stuff like the stuff for carpets, saw it in poundland for £1 each believe it or not :lol:
Forfarian
Postby Forfarian » Sat Feb 11, 2012 9:54 pm
Heavy duty wall paper paste works OK but as stated in an earlier post let it sit and expand.
PVA and water is just as good, but I size the area i'm going to stick the mat on.
aka Forfarian
cmeonthemove
Postby cmeonthemove » Sun Feb 12, 2012 11:15 am
If you're sticking the mat to a flat surface, you might want to try double sided tape.
royeslough
Postby royeslough » Mon Feb 13, 2012 5:23 pm
OK the results of my test.
The Wallpaper paste appeared to do a good job, but the following day I was able to peel it from the baseboard with ease. I believe the glue had been absorbed too easily into the baseboard. I guess this would be good if you wanted the ability to change your mind OR remove sections of grass for buildings/other scenic material.
However as I want it to remain firmly stuck down the PVA test was a far better bond. I cannot get the grass off again. This is probably as the PVA seals the baseboard.
SO for me PVA is the better.
PS I have used the carpet adhesive (surprisingly for sticking carpet) and it is an instant bond - giving no allowance to adjust the material, so with the grass matting there would have been creasing issues etc..
flying scotsman123
Postby flying scotsman123 » Mon Feb 13, 2012 7:00 pm
i told you PVA is the best adhesive known to mankind, i buy it by the bucketful :!: :mrgreen:
Return to “Scenery”
