Cast Brass Hornby Grange Chassis.
swiftbeam
Postby swiftbeam » Sat Dec 09, 2017 5:14 pm
Hi Guys,
Just bringing my info over from somewhere else to share with you as I'm no longer there!
I was doing a Bachmann split chassis Manor chassis swap for a Hornby Grange chassis. Everything went well until the Hornby Chassis snapped right at the end due to Zink rot. I thought that was a 60's thing, but apparently it still happens now. A very annoying lesson learnt!
So not to be beat, I glued and painted the now modified Grange chassis and got my brass caster to cast me a new Chassis from lost wax brass. This casting got the project back on track, but it was a total pain due to shrinkage. I had about 0.020" between the 1st and 3rd axle. After several days of problem solving and fitting and refitting, I had a running chassis :D
I had a spare Mashima motor, so I thought it would be a good idea to make that fit the chassis before the job was called 'finished'. This involved making up and soldering into place a nickel silver plate that fitted the motor perfectly and modifying the original Hornby rear motor mount.
I'd not recommend having a chassis cast in brass if yours rots due to zink rot, but this post shows it can be done! The upside is (apart from having the problem solved and a working model) is the brass casting is 21g heavier :D
swiftbeam
Re: Cast Brass Hornby Grange Chassis.
Postby swiftbeam » Sat Dec 09, 2017 5:15 pm
Ex-Pat
Postby Ex-Pat » Sat Dec 09, 2017 5:25 pm
Very interesting - what sort of money does a bespoke casting cost?
P.S.: Be careful not to drop it!
swiftbeam
Postby swiftbeam » Sat Dec 09, 2017 5:27 pm
£30 mould (can be used hundreds of times)
£10 for the casting
Total £40 plus postage.
Postby Dad-1 » Sat Dec 09, 2017 5:32 pm
swiftbeam, That sir is a neat piece of engineering.
I always fancied a Grange and Manor to fill blank spaces in my GWR
traction. I've since decided I already have too many locos anyway !!
Those prices almost acceptable although solving the shrinkage probably
was a trying fettling job.
GeraldH
Postby GeraldH » Sat Dec 16, 2017 10:52 am
That's an impressive piece of work. I've had two Hornby Toby chassis disintegrate from mazak rot. How did you resolve the shrinking problem?
Return to “The Workbench”
