Maroon Hornby Dublo emu(& others)
windcutter9f
Postby windcutter9f » Thu Nov 16, 2017 2:12 pm
Hi,i havn`t checked this forum for quite a whileThought you guys woud like pics of a mock up Rail blue Dublo emu.I`m experimenting with an MJT Cab front casting modified to fit a Mk.1 SD corridor coach,the problem i`m having at the moment are the jumper cables etc. on the front.I may have to make them as you can see in the emu trailer coach under construction for my Maroon three car emu.Also pics of my Maroon Dublo emu.I was given some tatty SD coach bodies & rather than scrap them,after scanning & prcessing in Photoshop,these are the results so far.
Ray
Re: Maroon Hornby Dublo emu(& others)
Postby mumbles » Thu Nov 16, 2017 2:22 pm
If you can get hold of them is this what you need? This is the front of an EPB
windcutter9f
Postby windcutter9f » Thu Nov 16, 2017 2:41 pm
Thanks,i was looking for a decent pic of them,the Dart Castings pic didn`t illustrate them very well.As you can see,the MJT casting needed modification to fit the Dublo sides.
Ray.
windcutter9f
Postby windcutter9f » Thu Nov 16, 2017 9:17 pm
Thought you might like to see the artwork for the blue emu.
Ray.
Postby Mountain » Fri Nov 17, 2017 8:15 am
It looks a very impressive project. :)
windcutter9f
Postby windcutter9f » Fri Nov 17, 2017 11:29 am
I`ll have to repost the artwork,i seem to have two of the same side on the LH side.This should be the corrected artwork
Ray
Return to “The Workbench”
