Following Mike Parkes’ post of 9th November 2017 here:
viewtopic.php?f=16&t=27613&start=150#p639913
I started researching what is popularly described as the Hornby Ski Slope A3 and found virtually a whole thread devoted to it on the other channel:
http://www.rmweb.co.uk/community/index. ... law/page-2
It’s first mentioned at (7) in Post number 26, occurring with “Book Law” initially and then other versions.
I persevered, read the whole thread, and then set to work on my 2 purchases of “Minoru”.
- This shows how the tender buffers are in line with those of the wagon.
- And this illustrates the problem by showing how the front buffers are not! – and you can also see the Ski Slope effect (although I think Aircraft Carrier is a better analogy).
- There is even a buffer height difference between the 2 models.
So, the bodies came off and finger/thumb pressures were exerted at the front to try and correct the footplate distortion. It was rather interesting to note that the 2 models reacted rather differently to the same technique.
The buffer steps on the first example fell off, but those on the other didn’t (rather annoying as the loco right-hand side step was splayed outwards, and took quite a bit of cutting and filing (of glue lumps) to get it off and glue it back correctly).
Also the second model emitted a rather loud cracking sound, and the pipes into the smokebox on the left-hand side came out! All fixable, but I’m glad it didn’t happen with the first model as it might have made me reluctant to start with the second model!
I’m now going to cover some basic procedures for anybody who would like to rename a loco but has not felt confident enough to do it.
- This shows the etched nameplates with one each of the number and name plates having been cut out (using Xuron photo-etch shears). You just need to be careful not to bend the plates as you snip them out of the etch. You can see where I have made what I consider to be stress-free snips.
You then need to decide whether or not to remove the existing nameplate. If you do then it is more fiddly to glue the new one perfectly upright. If you don’t then you might have an unacceptably thick nameplate with the new glued on to the old.
Of course you may have no choice in the matter if your chosen new nameplate is shorter than the existing and in which case you will have to remove the existing.
- Here I have snipped off the existing nameplate.
The new one is then simply fixed in place.
