m.levin's workbench thread
Postby m.levin » Thu Mar 16, 2017 7:19 pm
My current project is a HST class 43 BR full rake train.
To buy power cars and rake of coaches would break my budget, so it has come down to a bit of bashing.
I picked up a power car and dummy car off eBay for £15, spares or repair. The motor wouldn't run and that was just a pick up fault, a quick easy fix. So relisted the motor and wheels, as I had no use for them and got £13 back on the units.
I then purchased the latest Hornby drive gears and wheel sets for £14. Then made them fit in to the power car. Next step is motor is to fit a motor and weights.
This is the progress so far. With a comparison against untouched dummy.
Re: m.levin's workbench thread
Postby Dad-1 » Thu Mar 16, 2017 8:28 pm
That sounds like a Yorkshire bargain !!
Twas still brass that changed hands !!
Postby m.levin » Thu Mar 16, 2017 8:38 pm
Dad-1 wrote:That sounds like a Yorkshire bargain !!
A true Yorkshire bargain, a good one when you can buy a non motored HST for £2.
Postby m.levin » Thu Mar 16, 2017 8:43 pm
I wanted to re-motor for traction and power reasons. The old Lima motor would struggle to pull 8 coaches and dummy car. This will have front and rear bogie drive, with a stronger motor, this should pull the rake with ease.
I will test and add weight until I am happy, I will have inclines on my layout so the combination of traction, power and weight will be key, to ensure when the train hits the inclines it would struggle.
Return to “The Workbench”
