MILLSEND WORKBENCH/BREAKFAST BAR
railwayjim
Re: MILLSEND WORKBENCH/BREAKFAST BAR
Postby railwayjim » Mon Jun 01, 2015 2:33 pm
Now installed on the lift out section of "Millsend".
Next job for me is back to wagon building, a bargain from the local model shop, an LNER Brake van kit by Parkside Dundas.
Only £1.50 WOW in a bargain bin, an unopened kit. Did I need one? ...... no, could I resist it? ...... no.
Jim.
Postby Dad-1 » Mon Jun 01, 2015 7:20 pm
Would I need a LNER Brake Van ... No, would I have bought it at £1.50 ...Yes !!
Some serious bridge building there Jim, looking good.
railwayjim
Postby railwayjim » Mon Jun 01, 2015 8:30 pm
Thanks Geoff, it has been a bit of a build really, but pleased with the end result.
A short diversion from wagon building, but after the bridge saga, I am glad
to be back on wagon kits once again haha ..... and at £1.50 who could resist.
I will certainly be checking out the bin on my next visit to the shop!
Hope you enjoy the bogie borail and mineral wagon kits you've ordered, I will
watch for progress reports eagerly.
Jim.
railwayjim
Postby railwayjim » Tue Jun 02, 2015 9:50 pm
Tonights bargain basement project.
An old Parkside Dundas LNER Brake Van, just read they lasted till the fifties, my layout is sixties,
but surely one must have survived till then?
Postby Dad-1 » Tue Jun 02, 2015 10:00 pm
Hi Jim,
If not in general revenue traffic I bet they were in 'Departmental' use. Without diagram number I
couldn't confirm, but David Larkin's BR '68-73 says it were so.
railwayjim
Postby railwayjim » Tue Jun 02, 2015 10:05 pm
Think you're probably right Geoff, departmental use.
One things certain, one lasted long enough to be on Millsend, well it will do when its finished!
Jim.
railwayjim
Postby railwayjim » Wed Jun 03, 2015 3:19 pm
Well looks like another diversion from wagon kits!
Backgrounds have arrived this morning, so back to the layout for me it seems.
A couple of new backscenes, an old factory to cut out and detail and a set of arches, similar to a set I bought and give a 3d makeover to in my other topic "backscenes".
They are both 900mm x 250mm in size giving a good expanse.
As mentioned in my other topic, available from Munro Print, tel. 01253 863388, email: sales@munroprint.co.uk. At only £5 per background + p&p I think a good price.
Pictures of the completed scenes when complete. These are how they arrive.
Jim.
OO Gauge Industrial arches Banner.jpg (224.01 KiB) Viewed 1310 times
OO Gauge Derelict factory Background900x250.jpg (207.46 KiB) Viewed 1310 times
railwayjim
Postby railwayjim » Sun Oct 18, 2015 12:34 pm
Hi everyone,
Well with summer over, or what summer we've had, it's back to the railway time.
Over the summer I purchased, 'secondhand' a Bachmann Jubilee 'Kolhapur' with sound.
As usual with Ebay, it was described as 'as new', well needless to say it wasn't. cab doors missing,
but that was all and as this loco can be pricey secondhand I decided to keep it.
Another problem with these locos as discussed on many forums is the sound isn't great, so .....
I sent the decoder off to Olivia's Trains for a re-blow. On testing after the re-blow the sound was superb.
Whilst the decoder was being re-blown, I was contacted by Neil at Olivia's, who suggested a speaker mod.
This is simply putting a black gasket substance similar to blue tack around the base of the speaker, lifting it 3 or 4mm higher and
creating a chamber underneath. Which he supplied free. This has also improved the sound quality no end.
That done it is now time to change something else wrong with the loco, 'the drawbar'. This is a seriously long drawbar as can be seen in picture attached.
45593 as it comes.jpg (151.04 KiB) Viewed 1181 times
I presume it is to allow for quite tight radius curves, but does look wrong. So I replaced this with one I made myself, a whole 3mm shorter
which now 'I think' looks much better and negotiates all the curves on 'Millsend'.
footplates 001a.jpg (248.08 KiB) Viewed 1181 times
The other jobs before sending it off for weathering are the cab door replacement, these I am going to have a go at scratch building and also
the cab floor, which I am going to extend over the gap to the tender. These 2 jobs are also going to be done on a black 5 I have No. 45156.
footplates 002a.jpg (239.2 KiB) Viewed 1182 times
Luckily I have another black 5 No. 44875 (see picture) which has both sets of doors intact and has had the floor extended already.
I will post pictures as I progress with the additions to both locos.
This final picture shows the doors and extended cab floor, this is how they will both look. (Hopefully).
Jim.
footplates 003a.jpg (123.96 KiB) Viewed 1182 times
skyblue
Postby skyblue » Sun Oct 18, 2015 1:55 pm
The shorter drawbar is a definite improvement and should look even better once you've got that gap in the cab floor sorted.
Postby Dad-1 » Mon Oct 19, 2015 10:23 am
Nice going Jim.
I must check my Jubilee drawbar, I may be wrong, but something I have has two holes so you can
get clearence for 1st radius, or close up.
railwayjim
Postby railwayjim » Mon Oct 19, 2015 3:51 pm
Skyblue:....The drawbar is a simple fix but testing on your tightest curves is crucial, but improves the look dramatically.
Geoff T:....The Jubilee 'Kolhapur' drawbar has only one hole unfortunately.
Thought I would tackle the black 5 first.
A simple floor using plasticard, measuring twice and fixing once, a little tricky as this loco has fixed wires from loco to tender,
having had sound retro fitted, meaning the loco and tender couldn't be parted to get better access.
The doors again are just plasticard, half cut in the centre to look like they are hinged and painted matt black before fitting, then crew added.
The following pictures show the gap and missing doors before starting, test fitting and finally back on 'millsend' with its sister loco.
The Jubilee is next!
Jim.
before fitting.jpg (226.3 KiB) Viewed 1152 times
dry fit of cab floor and doors ready for paint.jpg (206.15 KiB) Viewed 1152 times
Must tidy those wires underneath!
And back on the layout.jpg (204.11 KiB) Viewed 1152 times
sister loco with original doors and floor added previously.jpg (212.48 KiB) Viewed 1152 times
railwayjim
Postby railwayjim » Thu Oct 22, 2015 12:56 pm
Just a couple of pictures of the Jubilee 'Kolhapur'.
Now fitted with shortened drawbar, cab floor extended and cab doors inplace.
Still need to mix a closer matching green paint for the doors top coat though.
All in all a vast improvement (in my opinion).
Jim.
Before any work was started
45593 as it comes.jpg (151.04 KiB) Viewed 1133 times
Jub back on the layout 1.jpg (241.19 KiB) Viewed 1133 times
Jub close up on layout.jpg (236.29 KiB) Viewed 1133 times
railwayjim
Postby railwayjim » Sat Oct 24, 2015 10:37 pm
Another project started (hopefully this will keep me off wagon building for a while)!
On 'Millsend' I have a raised corner behind some arches which I have never been happy with (are we ever).
factory-warehouse 003.JPG (223.66 KiB) Viewed 1114 times
I have decided to build a warehouse kit to fill this space, 'Millsend' being industrial, this seemed the right building for it.
Having built one as low relief before, it sits behind the station and fits perfectly, I am using the same kit for this build.
factory-warehouse 005.JPG (237.7 KiB) Viewed 1114 times
The kit is one of the 'City Classics' range, which are American, but can be made to look British with a little help. They are HO scale but being at the
back of the layout gives the impression of perspective They are available in the UK from quite a few retailers, this one was off ebay.
I have included this picture showing the kit laid out.
factory-warehouse 004.JPG (219.31 KiB) Viewed 1114 times
They can be cut easily being plastic and are sectional, so quite good for making different shaped buildings.
Progress so far, held together with blue tack and ready for some paint. The small single storey at the side will eventually
have a cut down dapol water tower tank sitting on top of it.
factory-warehouse 002.JPG (222.92 KiB) Viewed 1114 times
I will show more as I progress with this build.
Jim.
Postby Dad-1 » Sun Oct 25, 2015 7:14 am
I must look up where & how much these kits are.
As to being HO, the Americans tended to think big so I would imagine
their 3.5 mm to the foot would come out about the same as we would
have built over here in comparative 4 mm to the foot scale !!
As to keeping you away from Wagons ....... dream on, I bet you have a
few more before the end of winter !!
railwayjim
Postby railwayjim » Sun Oct 25, 2015 9:41 am
Geoff,
'Ah yes', still dreaming of wagons unfortunately!
Forgot to mention price, reasonable at £22.50 inc. carriage. (Ebay).
Much cheaper than Walthers-Cornerstone, but less choice.
Jim.
Return to “The Workbench”
