Quite a long time since I posted. The basic reason is the shortage of Bachmann short narrow tension-lock couplings
with their NEM pockets.
First I thought I'd add a picture of that Parkside LMS brake van with decals on.
Another task has been trying to catch up on some decalling. The Ratio GWR 5 plank wagon kits are great representations,
although it has to be said rather delicate. I've inherited half a dozen from Derry that I wanted to add to my existing models,
but for some reason they were in small plastic bags without any decals.
I checked my HMRS sheets and although I had enough decals to do the work they were rather different. Even the size of the
GW's for each side didn't fully match. I rang Peco who could supply me with the 6 sets I wanted, although being close to
Christmas I was advised they wouldn't be despatching until the new year, not a problem.
So tonight I decided to put some on. Oh Dear !!
The new decals are printed on a highly glossy film which does not respond to Microsol fluids. The film is rather stiff with poor
adhesion to my satin finish paintwork, yes I know high gloss is better, but interestingly the wagon numbers made up from
remains of my earlier decal sheets were fine.
24 hours after putting the decal on I thought I'd give another wetting of Microsol fluid which was enough to float the decals off
and they moved by gravity when the model was moved up to 45 degrees !! Crazy !!
Now my last two Iron Mink wagon kits had similar quality glossy decals - they do not stick well, lifting as they dried and as said
Microsol fluids couldn't get them to conform to surface detail.
I'm tempted to write to Peco, I know they think complainants are just poor modellers and it's not their product defect.
I suppose I should try on behalf of those who will be buying the kits, even for their reputation for quality.
Tonight's workbench
Soaking in Microsol fluids, the old decal cut up numbers responding as expected.
All rather disappointing.
