Thank you
The airbrush was from
https://www.everythingairbrush.com/ and the compressor was from eBay - it came with two cheap airbrushes as well which i swiftly got rid of
the tank on the compressor makes allot of difference to the noise levels & is well worth the cost difference (at the time was only around £15 more)
as to the airbrush, i cant recommend it enough its such a pleasure to use & puts up really well with my not so careful cleaning of it! it does get blocked a fair bit but its more down to me not cleaning it out well enough each time i put it away (normally because i think i will use it again soon but ends up being weeks between sometimes).
The airbrush comes to bits easily but more importantly goes back together easily as well, it strips down into about 5-6 bits when cleaning it & its obvious where it all goes when putting it back together again - i can strip it down and put it back together in a few minutes.
when it gets blocked & it wont clear with white spirit etc i have taken to threading a very fine bit of wire through the nozzle and running it back and forth which clears it out really well - just make sure the wire is smaller then the nozzle size!
The only issue i have had (my fault entirely) is the original nozzle split while i was trying to clean it out / unblock it with a toothpick - i must have given it to much pressure and it split the nozzle. It does highlight another brilliant thing about it however - spare parts are available!
Simple answer is the only reason i still use my airbrush is thanks to the ease of use of the Ultra, i had got very fed up with the cheap nasty ones which very nearly put me off.
