Dapol C017 Signal Gantry dimensions
Tom@Crewe
Postby Tom@Crewe » Mon Jul 17, 2017 7:19 pm
Has anyone got the Dapol C017 Signal Gantry Height and Width dimensions please....thank you
Never enough time...........
Re: Dapol C017 Signal Gantry dimensions
Postby Dad-1 » Mon Jul 17, 2017 8:56 pm
Sorry, a Dapol kit I've never tried.
luckymucklebackit
Postby luckymucklebackit » Tue Jul 18, 2017 8:04 pm
From the base to the underside of the girder is 80mm and the girder is 18mm high, the width of the kit "out of the bag" was designed to span 3 tracks at set-track spacing, mine is extended to span 4 tracks.
Hope this helps
Tom@Crewe
Postby Tom@Crewe » Tue Jul 18, 2017 10:13 pm
Thank you luckymucklebackit.
But it is the span that I need to know.
Tom@Crewe
Postby Tom@Crewe » Wed Jul 19, 2017 7:26 am
Ok... Thank for help but I think I will use this gantry (not for signalling) I was unsure if I needed 2 or 3 depending on the span, so what I have done is order one then measure up and order others if needed.
I will add measurements here for others to see if they need them.
Tom@Crewe
Postby Tom@Crewe » Fri Jul 21, 2017 12:28 pm
The Dapol C017 Signal Gantry arrived this morning so here are the measurements.
First of all they are as Luckmucklebackit said "From the base to the underside of the girder is 80mm and the girder is 18mm high"
The span if built as instructions is 162mm this is in two sections with a 1mm centre piece, the shortest section being 71mm and the longest 90mm so it can be built as 71mm, 90mm or the full 162mm span.
Return to “Dapol”
