Tutorial – How to respray your loco’s.
For this tutorial I will be using a Heljan Class 47 to demonstrate the techniques and practices I use to respray my locos. I have divided the tutorial into several parts, so each part can be done individually at any one time. The whole process of spraying a loco can take a week from start to finish and that doesn’t include detailing, adding transfers and lights, etc.
IMPORTANT:
Please read the ‘You Will Need’ sections at the beginning of each Part to ensure you will be able to complete the tutorial successfully (or so that you know what you will need to purchase in order to complete the tutorial).
NOTE:
24 Hours (minimum) must be left between coats to allow the paint to dry and to cure to the loco surface. Taking shortcuts will result in poor results.
Part 1: Paint Removal
You will need the following before starting Part 1 of this tutorial:
• A baking tray (one that you’re not going to use in the kitchen again).
• An old tooth brush (not the wife's, she will be able to taste it - Believe me! )
• Some Dot 3 brake fluid (or similar paint removing product).
• Your loco.
1. Remove the body from the loco chassis and store the chassis somewhere safe and out of harms way.
2. Now remove all windows, handrails, lamp irons, windscreen wipers, etc. and anything else that is removable from the body.
3. The loco is now ready to be stripped of its paintwork. Pour an adequate amount of brake fluid into your baking tray to cover one side of your loco. I have tilted my tray by wedging something underneath the one side of it. This simply allows the fluid to run to the end of the tray that the loco will sit in. I recommend you add a small amount of fluid to the inside of your loco body to make sure it doesn’t react with the plastic. Then, if you’re happy with the test, place the loco into the tray.
4. The time you leave the loco body to soak will depend greatly on the make of the model you are using. This Heljan Freightliner Class 47 will need to have a long soak as Heljan use a screen printing method for the logo on the side of the body. I am leaving it in for 20 minutes. You can always lift it out to see if the paint is flaking.
5. The next job is to use your old tooth brush to scrub the loco body. Don’t be tempted to use a new tooth brush, its bristles will be too hard and may scratch the body side.
6. Rinse away any residue under the tap and continue scrubbing. You will now be able to clearly see how much paint has been removed, and how much still remains. You will need to repeat steps 4, 5 & 6 until the loco is completely bare.
7. Make sure your loco body is rinsed thoroughly under running water and then dry by dabbing with kitchen towel. Leave to dry for 24 hours before continuing onto Part 2.
Finished loco body, ready for primer.
Mark.
NRM Article - Respraying Your Loco's - Part 1: Paint Removal
Why do we learn Algebra....!! We've no intention of ever going there!
With the Heljan 47, there are two layers of different types of paint. The top layer (which has now been removed) contains the actual Freightliner green colour, Freightliner logo's, numbers, etc. The under layer is a very hard and would need a few hours soak in the brake fluid. Personally, I prefer to leave this as it will save me painting the yellow ends on. All I'll have to do at the moment is mask the ends up and spray the body sides and roof. It's just down to personal preference.
Mark.
Mark.
Good work.
This is a artical that is long over due. I have a class 55 lima and the paint to re-paint it but just havent got to it yet.
looking forward to part 2
https://www.newrailwaymodellers.co.uk - Model Railway Advice
https://www.newmodellersshop.co.uk - Model Railway Shop
https://www.railwaypictures.co.uk - Railway Photo's
