NRM Article - Siding detction circuits.
Articles which have been added to the main site
headshot119
Postby headshot119 » Wed Dec 12, 2007 6:42 pm
Here is my article for the main site, all about siding detection circuits.
Please give constructive criticism.
Siding detection project.
Do you have a siding on your model layout that you can't see, do your trains hit the buffers causing damage to your locomotives. Or do you want to see at a glance on your layout control panel what sidings are occupied by locomotives. Then here is the answer. A siding detection circuit.
The idea of the circuit is to detect a locomotive in a siding, either because the siding isn't in plain view or you want to see on your control panel what sidings are in use. There are several different options you can add to the basic circuit, such as an on-off feature or a location feature, this is used in longer sidings used for full length trains, more on this later.
The most basic circuit is made up of three components and some 2mm wire. The component list is
1 LED
1 1K resistor
1 Diode
2mm wire
The LED should preferably be a low voltage, and not an ultra bright, trust me you don't want a control panel full of ultra bright LEDS. Now here is the circuit diagram.
The circuit should be placed over a rail gap connected to the next piece of track with an insulated rail joiner. (Fish plate) The circuit is only needed on one side. Now there are two places to put the circuit, either place it beside the track with wires running to the LED on the control panel. The Diode and resistor are hidden under ballast. Or you can put all the components behind your control panel.
The circuit works in a very simple way, when the last set wheels on the locomotives crosses the rail gap, no more current gets to the wheels because the diode only lets power through in one direction. This illuminates the LED showing you the siding is occupied, no matter how much power you apply. When you change the locomotives direction the locomotive will move again. The LED turns off and it shows you the siding is unoccupied. A very simple beginners circuit.
The next circuit is a siding detection circuit with an LED indicator and an ON-OFF feature. This is handy for platforms where you can automatically stop trains after the locomotive has passed a certain point and the control panel will tell you the platform us occupied.
The platform circuit is made up of the following components and some 2mm wire. The list of components is as follows.
1 LED
1 1K resistor
1 diode
1 SPST ON-OFF switch.
The circuit should be placed over a rail gap connected to the next piece of track with an insulated rail joiner. (Fish plate) The circuit is only needed on one side. Now the circuit can either be placed with the diode and resistor under the ballast beside the track with wires running to the switch and LED on the control panel, or behind the control panel.
The circuit works in a very simple way, when the last set wheels on the locomotives crosses the rail gap, no more current gets to the wheels because the diode only lets power through in one direction. This illuminates the LED showing you the siding is occupied, no matter how much power you apply. When you change the locomotives direction the locomotive will move again. The LED turns off and it shows you the siding is unoccupied. The switch allows you to chose to have the circuit ON or OFF handy in a station where you want passenger trains to stop and freight trains to pass through. This is also a very easy circuit for beginners.
Ironduke
Postby Ironduke » Wed Dec 12, 2007 8:15 pm
hiya Karl :^)
I think either the diode or the LED should be the other way around. Good idea though.
mark_brody
Postby mark_brody » Thu Jan 10, 2008 7:22 pm
I like the idea. Does it really work for DCC though, as the polarity is never reversed?
headshot119
Postby headshot119 » Thu Jan 10, 2008 7:32 pm
I don't know how it works with Dcc but it does.
Chuffer Chuff
Postby Chuffer Chuff » Thu Jan 10, 2008 7:49 pm
Mmm...thats interesting! Thanks for posting! :wink:
mark_brody
Postby mark_brody » Thu Jan 10, 2008 10:53 pm
Simple but effective, I'll give this a go.
sol
Postby sol » Fri Jan 11, 2008 5:02 am
Don't forget that DCC power is in reality a form of AC in a square wave format.
The 1K resistor & diode will certainly stop the train under DC but I think the diode would still let power thru on DCC on every other half wave - how DCC accepts that, I do not know but if it works - good.
regards
Ron Solly
Ironduke
Postby Ironduke » Fri Jan 11, 2008 7:53 am
sol wrote:Don't forget that DCC power is in reality a form of AC in a square wave format.
If the decoder supports Lenz' assymetrical DCC functionality the loco can either stop dead or decelerate (brake) or run at approx half full speed (believing the signal to be DC) depending on how you set it up. However I don't know if you can reverse the locomotive out again. I think you would have to bridge the diode with a switch.
I am fairly certain you do need to reverse either the LED or the diode in your diagram, Karl.
headshot119
Postby headshot119 » Fri Jan 11, 2008 4:04 pm
Here is the revised project for the main site. I'd like to say a big thank you to Ironduke who pointed out my very big mistake with the circuit diagrams. Please ignore the first set of diagrams and scroll down to see the correct ones. If Raider or another mod could delete the first post I would much appreciate it.
1 LED
1 1K resistor
1 Diode
2mm wire
1 LED
1 1K resistor
1 diode
Return to “Accepted Articles”
