I've cracked, or I've cracked it.
Hymirl
Re: I've cracked, or I've cracked it.
Postby Hymirl » Mon Aug 06, 2018 11:50 pm
I tip my hat to your space saving skills! I'm not brave enough to start cutting down points...
Very clever though. I like it
Postby Emettman » Tue Aug 07, 2018 9:52 am
Hymirl wrote:I tip my hat to your space saving skills! I'm not brave enough to start cutting down points...
Thank you.
On chopping points, do remember that here I don't have to worry about preserving electrical continuity: all the locos are battery powered.
The track is dead, not just the frogs!
With track power I've done nothing more than steal a sleeper space's length or two or three per point. It adds up over a ladder of points when space is tight.
At least computer planning software keeps you honest, unlike some of C J Freezer's earlier plans where he could be optimistic, shall we day, especially about curve radii.
Chris.
Postby Mountain » Tue Aug 07, 2018 6:59 pm
They can be shortened and made to work electrically. It helps to have a soldering iron ready. It is impressive to know what can be done with a little know how.
Postby Bufferstop » Tue Aug 07, 2018 11:36 pm
I once utilised a pile of settrack standard points to make the fan for my hidden sidings, it was easy to loose two sleepers from the entry track and one from each of the V rails, at the same time putting bits of rail into the frog to make them live. Closing up the spacing did cause one problem, the tiebars fouled on the adjacent sleepers, so I had to chop bits of the ends and fit the point motors underneath.
