Cheadle Bay - N Gauge in the round
- PinkNosedPenguin
Re: Cheadle Bay - N Gauge in the round
I like option 1 in your recent set of 3 plans - a two-road bi-directional fiddle yard hidden under scenery
You could make this into an end-to-end layout with a continuous run in the middle. DMU / 14xx with auto coach leaves platform at rear siding, at the first points takes the inside loop, goes round then takes the outer loop and into the front left sidings which have become the second station. Place a hill between the front and back stations that also gives the excuse for a tunnel and you have quite a satisfying little layout. You could even put in an extra point on the back siding / station to provide two platforms and a mix of three trains shuttling between them - just an idea.McScooby wrote:Another tweak: -
Thanks for all the replies and ideas, got too many ideas running round my head now.
I'm going to measure up my space again and where I can store it when not in use, if I can fit in the slight bigger base board in I'm going get that built as regardless of the plan that is kind of fixed.
I can then play around with what track I've got and see if it's entertaining enough or I need to add more and create one of the other plans. I'll post later hopefully if the bigger base board can be used.
42! What sort of answer is 42!
After a recheck of my space for running the layout but more importantly storing it I can get a 85cm by 70 cm board. I'm going to do some more tests but think I'm going to get my base board sorted in the next couple of weeks then start playing trains with what I've got before committing to a final plan.
Now can I do two baseboards and store them.........
Sounds like a plan.McScooby wrote: ...then start playing trains with what I've got before committing to a final plan.
Tut tut, - Essential research into the operational possibilitiesMcScooby wrote: ...then start playing trains with what I've got before committing to a final plan.
Sorry not use to the proper terminology yet , only use to working with IT, have you tried turning it off and back on again? Are you sure there is paper in the printer? I think it might be a PIBCAK issue!Bufferstop wrote:Tut tut, - Essential research into the operational possibilitiesMcScooby wrote: ...then start playing trains with what I've got before committing to a final plan.
That was a new one on me, when I bailed out we used to close calls with the tag OTATSP, the O was operator. I've still got the BOFH tee shirt, bit loose on me these days.McScooby wrote:Sorry not use to the proper terminology yet , only use to working with IT, have you tried turning it off and back on again? Are you sure there is paper in the printer? I think it might be a PIBCAK issue!
Can't beat a good BOFH story off the Register.
Speaking of IT, meant to post an update this weekend but due to a 3 hour job turning into a 16 hour one! I ran out of time.
After looking at what I could do regarding space I could only realistically increase my board size a little bit. I have space to setup a larger one but not to store it. Well store it in the house, I could put it in the shed but I don't want to do that as that defeats the whole object of the project at the min.
My final board size is 80cm * 65cm, this would allow my original plan easily or this one: -
As my baseboard size is fixed I'm getting the wood at the end of this week and aim to build it over the bank holiday weekend. I'm picking up the extra track I need for this plan as well so once by board is built I can conduct some " Essential research into the operational possibilities".
I will start a new thread in layouts under construction once I have the baseboard parts.
I've started to build this layout so I've begun a new thread which can be found here http://www.newrailwaymodellers.co.uk/Fo ... 65#p611465
