Round Layot N Scale
timon220
Round Layot N Scale
Postby timon220 » Wed Oct 13, 2010 6:41 am
Greetings to all! My name is Artem! I from Ukraine. I represent on your court process of construction of a small breadboard model on the scale of N.
All materials were not specialized property and undertook with a stress on cheapness!
The fence has made of small nails and has connected their thin wire!
Grass - powder for indoor plants
Trees - self-made
A food on rails in the form of tulips and 220V on illumination!
Self-made columns of illumination!
The wires feeding lamps, last outside!
Deltic1981
Re: Round Layot N Scale
Postby Deltic1981 » Thu Oct 14, 2010 11:11 pm
Thats pretty good for small layout
Terrier
Postby Terrier » Thu Oct 14, 2010 11:22 pm
Stratsvitsya Artem, very good work, a simple but very effective layout, and very good modelling. The buildings with the lighting are very good. :)
Terrier
bigbob
Postby bigbob » Thu Oct 14, 2010 11:24 pm
Nice, once the trees went on it made a big difference, love the lighting aswell :D
poliss
Postby poliss » Fri Oct 15, 2010 1:01 am
I would like to know more about the materials you used on your layout. It's almost of the 'Pizza' style, which I believe is becomming very popular.
timon220
Postby timon220 » Fri Oct 15, 2010 4:50 am
About which materials you want to learn?
BluePullman21
Postby BluePullman21 » Fri Oct 15, 2010 6:54 am
Great layout :wink:
When are you going to add people/cars etc?
Jack Middleton
Postby Jack Middleton » Fri Oct 15, 2010 7:44 am
That's fantastic :D
timon220
Postby timon220 » Fri Oct 15, 2010 8:00 am
If it is fair, this breadboard model has a little bothered me! Here still it is necessary to add 1 power unit for street illumination. Because of that that lamps and light-emitting diodes in houses have different internal resistance all together they don't burn, but only separately (connection in parallel). THEREFORE I want to add 1 more power unit that all burned together. People and cars too was going to add, but while the inspiration isn't present :)
poliss
Postby poliss » Fri Oct 15, 2010 1:31 pm
Materials such as, what the telegraph poles, rail ballast and trees are made from. Also, I'm not sure what the powder for indoor plants is?
timon220
Postby timon220 » Fri Oct 15, 2010 2:23 pm
Cable columns are made of sticks, a wire. Insulators - beads! A counterbalance - a match!
Trees - from a wire, and leaves - from a parabosom painted!
rail ballast is made of powder for an aquarium. Has bought in pet-shop.
Grassy covering - powder for indoor plants. Also painted with green gouache (dark zones)!
poliss wrote:Also, I'm not sure what the powder for indoor plants is?
The translator has badly translated this sentence! I won't understand an essence!
poliss
Postby poliss » Fri Oct 15, 2010 2:40 pm
If you can write it in Russian, Artem, I can get my wife to translate. :D
timon220
Postby timon220 » Fri Oct 15, 2010 4:56 pm
It is not necessary! I simply haven't understood that you meant! I haven't understood a question! I can not translate the written!
