First radius curves anyone?
Postby Bufferstop » Thu Nov 30, 2017 10:36 am
Check out this minimum radius junction.
https://www.youtube.com/watch?v=05luqG1pwUo
mahoganydog
Re: First radius curves anyone?
Postby mahoganydog » Thu Nov 30, 2017 11:08 am
Some very unhappy flanges there by the sound of things!
I wish peco would do a three way point that short.
luckymucklebackit
Postby luckymucklebackit » Thu Nov 30, 2017 11:26 am
According to Wikipedia the minimum curve radius on the Chicago "L" is 90 feet, which scales down in 00 to 14.17" (360mm) so it is actually slightly sharper than 1st radius which is 14.6" (371mm) :D
But it does show you how sharp a curve 1st radius looks like in real life!
Postby Emettman » Thu Nov 30, 2017 11:52 am
And those are SHORT coaches. Important with minimum curves.
The more modern image the layout, the more this crops up as an issue?
At 4.00+, a look at some "what do I do here?" sleepering from a model railway layout.
Chis
luckymucklebackit
Postby luckymucklebackit » Thu Nov 30, 2017 12:46 pm
Emettman wrote:And those are SHORT coaches. Important with minimum curves.
Chis
.. and if you look at a close up of the coaches (example Image you can see that the bogies are positioned very close to the ends of the coaches to minimise overhang at the coach ends
Postby Bufferstop » Thu Nov 30, 2017 2:46 pm
Emettman wrote:.
Chis
Yes, noticed that, I've never seen radial sleepering before. When the curve is so sharp and the sleepers span supporting girders it becomes almost inevitable.
BobDM
Postby BobDM » Tue Dec 05, 2017 7:20 pm
How does this compare with the curve at Morpeth?
Postby b308 » Tue Dec 05, 2017 9:34 pm
Well Morpeth is nowhere near as sharp as that for a start, it's 50mph and if you tried them at 50 they'd be on the floor underneath in no time!
There's been an interesting discussion on sharp curves on BR on RMWeb which is worth a read:
http://www.rmweb.co.uk/community/index. ... ine-curve/
luckymucklebackit
Postby luckymucklebackit » Wed Dec 06, 2017 11:26 am
Morpeth is 340 metres radius, which would be around 14.6ft Radius in 00! Converting backwards, a 24" radius curve, considered a reasonable radius in 00 works out at 46.4m radius
