Bachman Gordon
forest446
Bachman Gordon
Postby forest446 » Fri May 08, 2020 4:58 pm
Hi all
Got my Bachman Gordon out to run it up an down A small straight just to keep locos moving
Layout has been down a fair while now
An it started to produce blue ish smoke but no burning smell.
Could it just be dust or is it the motor letting me know it’s about to die
Loco easy 7 year old but not done massive amount of running an
Had been stood 2 years
A railroad engineer must be sure not to loose his train of thought or he might go down the wrong track.
Re: Bachman Gordon
Postby Dad-1 » Fri May 08, 2020 6:52 pm
Hi forest446,
There is a good chance it's burning oil that's crept into places where you
don't want it !!
I've had a loco smoke for that reason, also not running, but a thorough
clean up including gaps in the commutator had it working superbly again.
It's surprising how far oil & grease can creep, particularly if stored in a
loft that can get very hot in summer.
Re: Bachman Gordon
Postby Bufferstop » Fri May 08, 2020 6:54 pm
Geoff and I seem to be in agreement.
If it moved ok or perhaps a bit on the slow side, the fist thing to do is clean out any old lubricating oil or grease, if you aren't sure about doing this take it to a dealer who can service it for you. Bachmann Thomas series of models are imports from America, I doubt Bachmann Europe can deal with it. If it came from Tootaly Thomas, it may be worth contacting them.
Re: Bachman Gordon
Postby Bigmet » Fri May 08, 2020 10:04 pm
I am pretty confident on most models but the moving eyes...
https://www.bachmanntrains.com/home-usa ... /58744.pdf
forest446
Re: Bachman Gordon
Postby forest446 » Fri May 08, 2020 10:55 pm
It ran ok stripped it cleaned it oiled it
Ran for about a min on rolling road went fast then crawled the blue smoke appeared an stopped
Will try do a full strip down can order complete motor an gearbox.
The loco is easy 10 year old if not more it’s one of the first ones made they were like £30 unlike the £90 they sell em at now
Re: Bachman Gordon
Postby Bufferstop » Fri May 08, 2020 11:15 pm
@ Bigmet, if it's like Percy the moving eyes mean all the more space to put in a bit of weight. I cannibalised a Percy and a couple of Greggs, Geoff T had the DCC boards out of the Greggs, I think I've still got Percy's eyes somewhere if you feel tempted to create a new Thomas character. :roll:
forest446
Re: Bachman Gordon
Postby forest446 » Sat May 09, 2020 9:25 am
Ha ha
I Have just about finished Molly waiting on the boiler bands and lining delivery.
Merlin and Boco done an Rebecca is getting there
So won’t be doing any more customs for a while
Re: Bachman Gordon
Postby Bigmet » Sat May 09, 2020 2:07 pm
I'll give that a miss! I have one Bachmann Thomas body on a different Bachmann mechanism to entertain children with the 0-200 mph in 3 seconds performance that I have set up. He's a very naughty engine.
She is much too old for this sort of thing now, but one small girl didn't need the faces or colours to be able to classify the locomotives per Awdry. There were difficulties, too many different Gordons (ECML pacifics) and several types of locos that Awdry never covered, especially the 2-8-0s. We settled on Fred the freight engine for them.
forest446
Re: Bachman Gordon
Postby forest446 » Sat May 30, 2020 4:23 pm
Well took the motor out ran it on test bed I have for running motors after I service them connected it got it running for about 15 seconds then it caught fire an that’s no understatement
Any idea on the motor size Bachman U.K. dont stock spares an USA website still closed
Re: Bachman Gordon
Postby Bufferstop » Sat May 30, 2020 4:53 pm
Take a look at 12volt motors on Ebay, if you can find a visual match then there's usually an accompanying drawing of the dimensions. I've bought several motors on there, the only thing you need is a worm puller, or some way of doing it yourself, 2mm slot in a brass plate across the jaws of a vise and a steel punch works. Try the sites for Plazzajapan, Bea_studio and Banggood.
Bachmann will currently have no stocks for historic imports, but they've just taken up the licensing that Hornby held, so that situation may well change.
forest446
Re: Bachman Gordon
Postby forest446 » Sat May 30, 2020 6:43 pm
That’s what I was hoping they had already got spares in but not so the gear is an easy one it’s a plastic lose fit but so far eBay coming up short found couple of Hornby direct swops way cheaper but just not this one
whufcfan
Re: Bachman Gordon
Postby whufcfan » Fri Jul 31, 2020 11:28 am
https://estore.bachmanntrains.com/index ... cts_id=782
Is this any good, I went all the way through to check out, just under $20 .00 + shipping.
Return to “Bachmann”
