Hello,
For my new layout, I'm thinking of using Bachmann points 36-872 and 36-873. As usual, before making a lot of mistakes, could you give me a few advices ? Thank you.
Bachmann points
Re: Bachmann points
Theses are set track points and are identical to the Hornby points.
If you are going to use set track points why not use the Peco ST240 and ST241 which in my opinion are far better, made in the UK and on the same website are only £9 each.
My pictures :- http://s306.photobucket.com/albums/nn27 ... y%20Photos
My new Layout Upsand Downs:- viewtopic.php?f=22&t=40818
Re: Bachmann points
Its interesting that these points are described as 'non-isolating & perfect for DCC', if you look at the picture the use of plastic in the rails looks identical to an isolating point, meaning that the electrical pick-up properties from a DCC point of view will not be improved. Has anyone had any experience, or been able to examine, one of these points?
Re: Bachmann points
To try to clarify I have sent the below message to Hattons Web Site
The use of plastic in the rails looks identical to isolating points. If this is so there will be no improvement in electrical pick up. If this is so then the only benefit for DCC would be no need to provide additional electrical feeds to spurs etc. Is the picture shown a picture of the non isolating point, or a stock picture of a set track point? .
(They certainly don't appear to be electrofrog...)
Re: Bachmann points
Thanks for your help gentlemen. Waiting for hatton's answer.
Back on the track !
Re: Bachmann points
kebang wrote:Its interesting that these points are described as 'non-isolating & perfect for DCC'...
It's even more interesting that the position for a DC user isn't made explicit: these points will not isolate a loco in a siding, long the common practise in set track layout track plans, and consequently set track layouts. As for crossovers between two independently powered DC tracks, not suitable at all unless the rail connectors are changed to insulating type. As such it would be better to state 'Not suitable for DC layout use'.
I can anticipate the questions arising from an innocent purchaser unwittingly mixing these points on a layout with the conventionally isolating type, and then finds locos moving when the expectation is that they are isolated (and derailing when they come to the incorrectly set point) as the first and simplest of the resulting problems.
Is this quite a recent change from Bachmann?
Has anyone purchased and found out whether Bachmann make this explicit? They should really be sold prominently labelled 'DCC only', with instructions for the user modifications to suit DC operation.
Supplementary question. Why have Bachmann done this, could it be retailer input that the majority of set track sales are now going to customers building DCC powered layouts?
Re: Bachmann points
The points are electrically the same as settrack points with the DCC conversion springs that Hornby sells. I'd say does anyone know if the switch rails are isolated or is shorting to the wheelbacks still a possibility. Certainly they may be troublesome if used on DC. They remind me of Hornby Dublo's first disastrous attempt at two rail points.
Re: Bachmann points
Many thanks for all your replies gentlemen. Very interesting and very helpful. Once again, Thanks.
Very good advice. It's exactly what I'm gonna do.
beejack wrote:...why not use the Peco ST240 and ST241 which in my opinion are far better...
Back on the track !
Re: Bachmann points
Hattons replied. To summarise: They are set track points that do not isolate. As Bigmet said they are going to cause problems for beginners trying to use them as crossovers or expecting their DC Loco to be isolated when in a siding.
