Bachmann EZ Command, Missing Red Lead
fholred
Postby fholred » Thu Oct 20, 2016 9:06 pm
I've just been given an Bachmann EZ Command but it is missing the red lead to connect the controller to the track. Does anyway know where i can get from? , already looked around the usually places but no look
Suzie
Re: Bachmann EZ Command, Missing Red Lead
Postby Suzie » Fri Oct 21, 2016 12:53 am
It is just a stereo 3.5mm jack plug, so should be easy to make one up. The same cable is used with the DC controllers, so someone might have a discarded lead with a trainset controller that is no longer used.
Suzie x
fholred
Postby fholred » Sun Oct 23, 2016 8:38 am
Could you then just get a lead with 3.5mm jack plug on one end and strip the other and solder to the track, would that work?
kebang
Postby kebang » Mon Oct 24, 2016 3:44 am
Be Careful! many made up leads with 3.5 jacks are only designed for audio use. The amperage from the EZ Command could easily melt the insulation on the wire and cause a fire.
trainlover23
Postby trainlover23 » Mon Oct 24, 2016 9:14 am
Why not try a local model shop and ask for part no 36-611 or is that to easy
dubdee1000
Postby dubdee1000 » Fri Oct 28, 2016 6:53 pm
trainlover23 wrote:Why not try a local model shop and ask for part no 36-611 or is that to easy
*too
trainlover23
Postby trainlover23 » Sat Nov 05, 2016 6:54 pm
*too
TA
thebritfarmer
Postby thebritfarmer » Sat Nov 05, 2016 8:34 pm
All Aboooooard !!
Return to “Bachmann”
