My 66200 which I bought second hand for christmas,fitted with a bachmann decoder,worked well for a few days,now however,it doesnt.It stops,starts and then when It does get going stops and doesnt start for minutes afterwards.I cant be the track as my other locos work fine?
Does anyone know what is the problem?
Its wheels are clean and its oiled,i don't know what could be the problem?
class 66 problems???
- Lewis Nash
NASHTON
ARPLEY STREET
Lewis[ArpleyModeller]
ARPLEY STREET
Re: class 66 problems???
Too much oil? Make sure the back of the flanges have not got any dirt or oil on and that the pick-up surfaces are clean and haven't got bent. My 66022 suffered from this.
- Lewis Nash
Hi Dave
No ,definitely not too much oil,i use a cocktail stick so only a few drops go on the gears.
I keep looking over it too see what might be wrong but still nothing yet?
Ill look at the pic ups,can you buy replacement pickups?
Thanks for helping though
Lewis
Lewis
NASHTON
ARPLEY STREET
ARPLEY STREET
One question I would ask is do the lights stay on when the motor stops, or go off and on as the motor stops and starts. If the lights stay on when the motor suddenly stops, then it is most likely the connection from socket to the motor where the problem lies. If the lights go on and off with the motor, then it is the pick up efficiency and connections betwen pick ups and socket that need to be looked at
Something that needs close attention are all the electrical connections to the main circuit board. The wires are clipped to tags around the edge of the circuit board, and I have found some of these connections to be loose on some Bach diesels. (Ideally solder the wires to the circuit board, as this is far more robust.)
Have you tried resetting the chip back to default if i remember once i had this problam with a DCC chip & when i reset the loco back to the original settings it working perfectly.
Simon.
Simon.
- dubdee1000
i'd echo what tinsleytmd says. If its starting on its own after "several minutes" i'd swap the chip out.
My work in progress : http://www.newrailwaymodellers.co.uk/Forums/viewtopic.php?f=22&t=24680
- Lewis Nash
Ive got a new chassis and am using the old one for spares.
Job done
Job done
NASHTON
ARPLEY STREET
ARPLEY STREET
- Lewis Nash
I was planning on buying one I was watching but was outbid!!!
So I posted I had bought one to end the topic when really I hadnt won it when i wrote it
NASHTON
ARPLEY STREET
ARPLEY STREET
