PNP's O-16.5 Workbench
PinkNosedPenguin
Re: Shall I swap scale/gauge to 0-16.5?
Postby PinkNosedPenguin » Mon Jun 25, 2018 8:08 pm
As threatened, here is a video of Doris and Mabel
This now completes Doris . . .
Postby Bufferstop » Tue Jun 26, 2018 3:50 pm
A delightful little fleet. Can't wait to see the home you create for them. In amongst the buildings perhaps, tight corners and wagon turntables!
PinkNosedPenguin
Postby PinkNosedPenguin » Sun Jul 29, 2018 8:05 pm
As mentioned elsewhere, I have been on holiday (and visiting family) in the USA. Whilst in Connecticut we visited the Essex Steam Railway where I noticed a Porter which bore a family resemblance to my recently converted loco (although the full size one was an 0-6-0).
Apparently:
On January 9, 2009, The Friends of The Valley Railroad, a volunteer organization working with the railroad to perform track work, equipment maintenance and many other tasks, took possession of Simons Wrecking #2, a Porter 0-6-0 tank engine from the city of Peabody, Massachusetts which had been part of the famed Steamtown collection. The engine will be cosmetically restored for the time being while donations are raised for the potential to return it to steam.
Photos below:
ImageDSC_0099 by Pink Nosed Penguin, on Flickr
ImageDSC_0100 by Pink Nosed Penguin, on Flickr
ImageDSC_0101 by Pink Nosed Penguin, on Flickr
ImageDSC_0102 by Pink Nosed Penguin, on Flickr
ImageDSC_0103 by Pink Nosed Penguin, on Flickr
Postby Mountain » Sun Jul 29, 2018 10:28 pm
Very nice. They have a very generous loading gauge over there. Even those little locos are large compared to ours.
PinkNosedPenguin
Postby PinkNosedPenguin » Sun Nov 11, 2018 6:27 pm
I decided to get my temporary 'layout' out again today and play trains :D. Good fun adjusting the speeds of my 4 locos so they kept a constant distance apart (oh the joys of DCC!).
Mind you, there were occasionally some significant hazards on the line . . .
ImageIMG_9210 by Pink Nosed Penguin, on Flickr
Last edited by PinkNosedPenguin on Sat Nov 24, 2018 2:57 pm, edited 1 time in total.
Postby TimberSurf » Sun Nov 11, 2018 8:45 pm
Do they do 8x4ft foosball tables?
Postby Mountain » Mon Nov 12, 2018 8:50 pm
Its great to see you back PNP with your lovely models. Your cat loves them too!
PinkNosedPenguin
Postby PinkNosedPenguin » Tue Nov 13, 2018 7:30 pm
Mountain wrote:Its great to see you back PNP with your lovely models. Your cat loves them too!
Thanks Mountain, yes it true. He (Pitch) was very interested in them, but luckily didn't take a swipe with his paw . . . :o
PinkNosedPenguin
Postby PinkNosedPenguin » Sun Nov 25, 2018 11:44 am
Yesterday I was pleasantly surprised to find I had a wagon kit I hadn't made up yet :D - a Smallbrook Studio Inside Bearing Tub Waggon. It took my fancy because of the 'inside bearings' configuration.
It is a simple kit to construct:
ImageIMG_9212 by Pink Nosed Penguin, on Flickr
It didn't take long to build & paint, and add some weathering:
ImageIMG_9217 by Pink Nosed Penguin, on Flickr
Here it is posed with Doris:
ImageIMG_9216 by Pink Nosed Penguin, on Flickr
PinkNosedPenguin
Postby PinkNosedPenguin » Thu Nov 29, 2018 7:15 pm
After seeing these slate wagons at LLechwedd over half term, I was inspired to add loads to some of my wagons :D
ImageIMG_9168 by Pink Nosed Penguin, on Flickr
Like the above I wanted to pack slate into a wagon, but probably not such thin slate! Hence I ordered some 1/24th scale slate roof tiles off ebay (intended for roofing dolls houses) which I thought might be an appropriate size. A pack of 250 of them duly arrived:
ImageIMG_9220 by Pink Nosed Penguin, on Flickr
I started by just laying a row in the wagon:
ImageIMG_9221 by Pink Nosed Penguin, on Flickr
Heartened by the look of this I filled the wagon and glued in place using watered down PVA - I didn't think it practical to make this load removable:
ImageIMG_9223 by Pink Nosed Penguin, on Flickr
ImageIMG_9225 by Pink Nosed Penguin, on Flickr
I also wanted to add some coal to the tub wagon I had just constructed, and found a video online from 'TeacherTiger' which showed an interesting technique. First you cut a small piece of polystyrene to fit into the wagon:
ImageIMG_9218 by Pink Nosed Penguin, on Flickr
The small nails were an attempt to allow the load to be removed using a magnet (though not sure if this will work as I haven't got a magnet strong enough!).
This was painted black and then, using the technique from the video, placed inside the wagon inside some cling film. Coal was then added dry, followed by spraying with water and adding diluted PVA (i.e. similar to ballasting track). At this point it looked like this (sorry for poor quality photo):
ImageIMG_9219 by Pink Nosed Penguin, on Flickr
After about FOUR DAYS drying time (!) I removed the cling film to reveal:
ImageIMG_9229 by Pink Nosed Penguin, on Flickr
Which looks like this in the wagon:
ImageIMG_9227 by Pink Nosed Penguin, on Flickr
To finish off this post, here are the wagons behind Mabel:
ImageIMG_9228 by Pink Nosed Penguin, on Flickr
Postby Mountain » Thu Nov 29, 2018 8:26 pm
Those slates look amazing.
Chops
Postby Chops » Fri Nov 30, 2018 11:07 pm
Remarkably ingenious!
Nessie rocks!
Postby TimberSurf » Sat Dec 01, 2018 8:18 am
I think the the Doll's house slates look superb! :D
I did a How To Video on the removable load, quite recently, the magnet on a wand was from a 'Pound' shop.
PinkNosedPenguin
Postby PinkNosedPenguin » Sat Dec 01, 2018 9:00 am
Thanks guys :D.
TimberSurf, yes that's the same technique in your video, only the one I followed did not mention the magnetic removal (I added that bit myself). However I think I should have used a larger piece of metal in the load (like you did) . . .
PinkNosedPenguin
Postby PinkNosedPenguin » Sun Dec 02, 2018 1:10 pm
Some Slimrails wagon kits I ordered arrived and I have constructed the first one = a box van with sliding doors.
These kits are well made, quite reasonably priced and go together nicely - I fitted the door closed on one side:
ImageIMG_9230 by Pink Nosed Penguin, on Flickr
and slightly open on the other side:
ImageIMG_9234 by Pink Nosed Penguin, on Flickr
Here is the completed wagon behind Ronald:
ImageIMG_9237 by Pink Nosed Penguin, on Flickr
