Shall I swap scale/gauge to 0-16.5?
Re: Shall I swap scale/gauge to 0-16.5?
Postby Mountain » Thu Oct 19, 2017 11:02 am
I believe I read somewhere the Peco Glyn Valley tram loco can be adapted to use an 0-6-0 chassis. Which chassis I dont know as I've not done it. Two of my locos are Smallbrook Studio kit conversions and one is scratchbuilt from a Hornby Smokey Joe type loco (Saddle tank).
Smallbrook do a little 0-6-0 diesel shunter which is designed to run on either a Toby the tram chassis or a terrier chassis (Which has to be specified which chassis you are using if ordering the kit). These chassis have quite a short wheelbase to them.
It maybe worth contacting Peco and ask what chassis people have used in the past for their kits. Their loco bodies were originally from another small cottage industry manufacturer (From what I have heard) and the tram loco was designed for the available chassis in its day which would have been the likes of Triang etc, though I do not know if it was a straight fit, or if the chassis was adapted etc.
Hornby first radius curves are ideal for this use. Nearly every chassis you will be looking at for narrow gauge use should go round first radius as few of us will be using larger chassis that won't get round.
I turn much tighter again but the tighter you turn the less can negotiate it. I should be OK with short wheelbase 0-6-0's but not sure yet about others for my layout. :lol:
Enjoy the adventure of this scale and gauge. No doubt, if you are like me you will be seen looking round all sorts of shops to buy unusual things you can use for scratchbuilding. Things like drawing pins, paper clips, tiny clothes fasteners and anything else that is cheap and looks like it may have a use!
Postby mumbles » Thu Oct 19, 2017 11:20 am
I took my Thomas tte apart to assess it as a donor chassis yesterday!
Postby b308 » Thu Oct 19, 2017 11:34 am
Any tram loco can be fitted with any mechanism you want as the skirts will hide it!
Going back to the OP and the two reasons given for changing, I assume that glasses will not correct the vision issue? Also regarding running, it doesn't matter what your scale/gauge is, bad running will take place regardless if the basics aren't done correctly and I've seen some pretty awful running on 16.5mm gauge (SG and NG) of late at exhibitions. It's far better to concentrate on making sure your baseboards and track laying is fit for purpose rather than move up a scale as if you make bad boards and lay track badly you won't solve the issue by moving up a scale...
There's plenty of RTR in HOe/009 which run well and are larger to use than N and you can use all the 4mm buildings and accessories.
One downside with O-16.5 is that everything is very LARGE, especially compared with N or OO standard gauge and that's worth considering as well... Buildings, for instance are very big in 7mm scale compared with 4mm, although if you model true narrow gauge then there may not be that many of them!
Choose your doner chassis carefully, going for the cheapest isn't always the best way forward... There are several decent 0-4-0 chassis that look better and run better than the cheapo Hornby items that everyone seems to go for...
There are a couple of other threads that you might want to read about NG modelling before you go for it, moving from SG to NG is quite a big thing, NG Railways are much quieter, have much shorter trains, and, in the main, don't run services like the Rush Hour at Clapham Junction... It's a very different type of modeling unless you already model Light railways in standard gauge!
viewtopic.php?f=29&t=50992
viewtopic.php?f=29&t=50356
In some respect it's a shame that Triang made such a pig's ear of TT scale when they did it! If we still had TT in this country like they still do in Germany and Eastern Europe that scale would have solved PNP's problems!
Postby Mountain » Thu Oct 19, 2017 11:45 am
mumbles wrote:I took my Thomas tte apart to assess it as a donor chassis yesterday!
Nice. The easiest conversions use most of the body of a donor loco. I have a Thomas myself and did have a look at it, though for me the 0-4-0's I had were my chosen option. I was also looking at the old Triang diesel shunter they called a class 08, as they are so robustly made, and very cheap to buy secondhand. A brief run through my back to back scratchbuilt points wasn't successful but I've eased the point angles since so it may work. If my memory serves me, it did go round my curves but it was tight against the check rail. Thoughts were considered about the possibility of shortening the chassis to an 0-4-0, though it may not be so easy as only the middle pair of wheels hold the con rods on. No threads in the outer wheels and no flanges on the inner pair of wheels.... :?
Postby mumbles » Thu Oct 19, 2017 12:03 pm
Not sure what ill do with it, i was googling for inspiration yesterday... Realised i need to work out what the dimensions would be in 7mm scale!
Postby Mountain » Thu Oct 19, 2017 12:17 pm
I can measure my roofline of my locos if you like. Also the height of a man would help?
Postby mumbles » Thu Oct 19, 2017 12:21 pm
Mountain wrote:I can measure my roofline of my locos if you like. Also the height of a man would help?
That would be helpful, and width of loco. Is there a site with 7mm loading gauge for NG?
Postby Mountain » Thu Oct 19, 2017 12:59 pm
Not sure about site as I've not looked. Sorry for delay as just run brothers wife to the bus stop.
Height of loco roofline (From rail height) for my Smallbrook Clio kit is 68mm but I'd allow for an extra 20- 25mm to allow for roof vents and if one has a brakevan with a lookout to it. Most of my coaches rooflines are about the same but roof vents add about 10mm in height.
Width for the wider Peco coach with the guards duckers is just over 60mm. Coach widths themselves with no duckers are about 45mm as are the Smallbrook locos I have.
Buildings. I recently purchased a home made 7mm scale GWR stables. (It has 4 mm scale brickpaper which I will address in the future, but it is a decent indication of size of a reasonable size building. It is not small but not large either, and is single storey.
Height is 113mm to the top of the chimney (105 to the top of the roof itself) which is about the same as roof vents. Depth is 100mm and length is 260mm.
Many similar buildings would be smaller or larger depending on the needs and materials and even the environment they are in. For example, in Wales in bad weather areas they build small to keep the heat in.
I hope this helps.
Postby mumbles » Thu Oct 19, 2017 1:06 pm
Cheers for that :)
Postby Mountain » Thu Oct 19, 2017 1:07 pm
mumbles wrote:Cheers for that :)
See amendment to above post for more.
Mattc6911
Postby Mattc6911 » Thu Oct 19, 2017 2:00 pm
Hi There, I'm slipping down the O 16.5 slope as well :D I've been picking up bits and pieces through the year so I can start putting something together this winter when the workshop is Baltic and work on the OO layout stops. The Mrs went madd last Christmas when I suggested she buy me a smallbrooke kit to try, No not in the way you think ! I sent her the link and listed 6 or 7 and asked her to choose the one she liked. . . She couldn't decide so bought 5 :lol: None of them have been built yet as family illness and subsequent passing on meant a year of long distance traveling which curtailed pretty much anything else being done.
I'm hopefull for a return to normality now and a quiet peacefull winter with some kit building and bashing .
Mountain that building looks great ! Would it be possible to put together a few bits . . A loco or two that you have done, bit of loose track etc and then put up a couple of photos ? This would help us new muggles to get an idea of relative sizes and perspective etc. I know there is tonnes out there via Google but it would give us a bit of a reference point to refer back too here (others who have also done some could join in as well ? ) Its to try and get an idea of the balance between Oo full O and O.16.5
Matt C
Postby Mountain » Thu Oct 19, 2017 2:55 pm
See Llwyndrissi Halt in the layout building section.
Here are a few pics for comparison between 00 and 0-16.5. The green loco is a Smallbrook Studio "Clio" kit on a old Triang chassis frame with modern Hornby 0-4-0 running gear. Coal bunkers have been made from plastic angled edging material (Sold in long lengths in hardware stores).
The black 0-16.5 loco is a simple scratchbuilt conversion. Plasticard cab with paperclip and wire used for internal cab details and paper clip to resemble roof rails for opening hatch, and an old watch battery painted to resemble a pressure gauge in the cab. The chimney is an empty ink cartridge from a fountain pen with the top cut off.
Also there is a standard Hornby Smokey Joe for size comparison.
Note. The black 0-16.5 loco has not had buffer couplings fitted yet, though the bufferbeams have been deepened ready. The buffers are made from drawing pins and the drop down loops are made from paper clips. The nameplates are made from aluminium fizzy drinks can cut and fed through a budget label printing tool.
Postby Mountain » Thu Oct 19, 2017 3:12 pm
A scratchbuilt "Open" coach made from lollypop sticks, tea sturers etc.
Postby Mountain » Thu Oct 19, 2017 3:23 pm
The skip waggon is made from using Peco rail as a frame and baked bean tin for the body. The wheels were purchased secondhand and look like H0 box car wheels.
The rusty Wagon contains real rust. It has a body mounted on a Triang metal coach bogie and the wheels are old Romford wheels (10.5mm) mounted onto the Triang axles using small plastic drinks straw slices as spacers.
Postby Mountain » Thu Oct 19, 2017 3:38 pm
Here is an easy project and cheap to build too!
The wood for the chassis is made from a small thin dowel bought from a hardware chain store. It is simply made in the form of a letter H. When I drilled holes for the wheels, they didnt sit straight so to remedy this, I opened up the holes to twice the size and drilled a tiny hole right into the centre of the chassis in an end to end direction (In other words I stood the chassis on end and drilled down the internal centre bit of wood). A small piece of springy wire was then inserted (Made from a single strand of a bicycle gear cable) and it was sandwiched over one axle, through the hole and over the next axle and was adjusted so it acts as a spring for the wheels without being too strong or weak. Careful bending made it just right.
While ideally try to get the axle holes right the first time, this is a bodge that created the novelty of suspension on the model, which most of the prototype didnt have!
The wheels are Hornby 12.5 disc wheels. I've yet to file the axle points down and I've not converted it to drawing pin couplings yet which will need slightly deeper buffer beams. The body was made from tea sturers with bicycle spokes cut for the uprights and thin drinks straw slices as spacers for the "Cage" bit fed over the spokes. The upper wood slats of the cage are tea sturers split lengthways in half and carefully drilled to go over the spokes.
