Peco SL-500 & SL-100
Beynac
Postby Beynac » Wed Apr 19, 2017 7:45 am
Hello,
It's question about Peco SL-500 and SL-100 track:
They are all "code 100" but is it exactly the same rail ? Can I connect them together without any issue ?
Many thanks for your help.
I'm just a guy who wants to play with his toys. Image
js1975
Re: Peco SL-500 & SL-100
Postby js1975 » Wed Apr 19, 2017 9:56 am
They're different guage right? SL-500 is narrow? In which case the rails may well be code 100 in height, but the horizontal gap between them won't be the same. The 4' in standard guage is not the case for narrow.
GWR_fan
Postby GWR_fan » Wed Apr 19, 2017 10:03 am
The remarks in this post caused the OP much offence. They have been removed to avoid any further offence.
Beynac
Postby Beynac » Wed Apr 19, 2017 10:48 am
The remarks to which this post referred have been removed.
GWR_fan
Postby GWR_fan » Wed Apr 19, 2017 11:26 am
Post no longer appropriate.
Beynac
Postby Beynac » Wed Apr 19, 2017 12:32 pm
Beynac
Postby Beynac » Wed Apr 19, 2017 2:32 pm
I found an answer in a French forum: SL-500 and SL-100 can work together without any issue (same gauge and same rails). :D
Postby Bufferstop » Thu Apr 20, 2017 1:27 pm
I thought I should check out the source and apart from a comment on one item, I couldn't find (by following a logical series of choices) anything on the Peco website to confirm that 0/16.5 track uses exactly the same profile as 00 code-100. Both the same height, yes, but compatible with standard 00 track only a comment under one particular item that 00 set and flexi track could be used to expand the range.
As a comparison 00/9 and standard N gauge rails cannot simply be joined together due to the extra buried flange on the bottom of the N gauge rail.
So I don't think it was unreasonable for Beynac to seek the benefit of others experiences. The English in some of his postings may seem a little simplistic but then I guess it's not his first language. The explanation of why he was asking, poses a question that I think most of us could not answer, "Is there an equivalent French phrase for Armchair Modelling?" If there isn't* then how would he translate the activity into English.
* Iv'e previously struggled to explain the difference between hidden track and a fiddle yard, to a German.
John W, aka Bufferstop and not wearing his Admin's hat.
trainlover23
Postby trainlover23 » Fri Apr 21, 2017 1:24 pm
js1975 wrote:They're different guage right? SL-500 is narrow? In which case the rails may well be code 100 in height, but the horizontal gap between them won't be the same. The 4' in standard guage is not the case for narrow.
The track gauge is identical ie 16.5mm . SL500 is designed for 0-16.5 scale models or 0N30 and SL100 is designed for use by HO/OO modellers . The sleeper spacing and size is different on the SL500 track so joining the two might be a problem
Postby Bufferstop » Fri Apr 21, 2017 2:33 pm
The major question is the rail section, for a good connection with fishplates they need to be the same, sleeper height can easily be overcome. From the comments on the Peco website (helpfully only as a remark on the details of some points) is that the sections are the same.
Beynac
Postby Beynac » Sat Apr 22, 2017 8:36 am
Thanks gentlemen for your replies and your help.
I bought one length of Peco SL-500 just for a try with a Peco ST-221 (fortunately I already have one).
kebang
Postby kebang » Sun Apr 23, 2017 2:16 am
Let us know how that works out Beynac, perhaps with a close up photo of the join?
Beynac
Postby Beynac » Sun Apr 23, 2017 6:06 am
For sure I can do that. You just have to wait a little while.
Beynac
Postby Beynac » Wed Apr 26, 2017 2:42 pm
It works ! There is just a slight difference between the height of the sleepers.
TRACK 02.jpg (93.9 KiB) Viewed 2378 times
kebang
Postby kebang » Thu Apr 27, 2017 3:14 am
Thanks for the picture Beynac. Well the rolling stock will negotiate that, but from an aesthetic point of view they do look quite different. Not sure how to disguise that....
