Worlsey Works Ffestiniog coach 14.
sir hayden
Re: Worlsey Works Ffestiniog coach 14.
Postby sir hayden » Thu Aug 18, 2011 10:08 pm
I might get all of the Parkside Dundas plastic Ffestiniog kits :D.
90733
Postby 90733 » Thu Aug 18, 2011 10:17 pm
sir hayden wrote:I might get all of the Parkside Dundas plastic Ffestiniog kits :D.
Though you were tight on money> :? As I said, don't spend loads of money then find out you don't like it ect... just get a couple first!
BernardTPM
Postby BernardTPM » Thu Aug 18, 2011 10:53 pm
You could even try building your own coaches from styrene sheet. I built this one when I was 20 (though it certainly wasn't the first coach I ever built - you learn a lot as you keep trying and styrene sheet is fairly cheap, certainly compared to etched kits!)
Basically it's a clear plastic box built round an interior. A normal compartment coach is easier than this one as you won't need to put as much detail in it.
sir hayden
Postby sir hayden » Fri Aug 19, 2011 2:13 pm
Thanks for the advice guys.
sir hayden
Postby sir hayden » Sat Dec 10, 2011 1:47 am
Well I'm working on HO and N first since those are the most common in the US while the other scales minus G and On03 are common in other places.
whynot
Postby whynot » Sat Dec 10, 2011 10:33 am
I think your understanding of having no money must be very different from mine!
dave j
Works End 0 16.5
viewtopic.php?f=22&t=49336
sir hayden
Postby sir hayden » Sat Dec 10, 2011 8:17 pm
What I meant was I will be buying stuff I can get in the US before working on the British stuff and I'm starting on it this Christmas because my grandparents are getting me some Bachmann HO Scale Thomas and Friends stuff for Christmas plus track and controller.
llanigraham
Postby llanigraham » Mon Dec 12, 2011 9:12 am
That sounds more like your level (at present)
sir hayden
Postby sir hayden » Tue Dec 13, 2011 12:02 am
Correct :).
