Thanks SRman, I thought that was the case but the 'spare' brown wire threw me. Hopefully I won't need the stay alive but wanted to be sure what I was doing before diving in.
Zimo MX600R
Re: Zimo MX600R
The brown is a function wire. The NEM652 8-pin plug does not have enough pins for all the decoder's functions. Get the PluX version (MX600p) and all the functions will be on pins.
Re: Zimo MX600R
With the MX600 the blue wire can be used for connecting a stay alive, but the ground connections are pretty awkward to solder to. I've done a few, but ruined one so I now use the MX617F where the pads are easy to solder to.
- Ironduke
Re: Zimo MX600R
heda wrote:My MX600R decoders have arrived, I know red and black to the track and orange and grey to the motor. I intend to snip off the connector and hard wire.
The other wires I will cut off but leave a short length (insulated) so that I can connect to them in future if I decide to add lights.
Whats puzzling me is that although the connector is 8 pin there are 9 wires, the 9th being brown.
My question is if I need to add a stay alive am I right in saying I need the blue wire which I think is +V
and does the other wire on the stay alive connect to the pad at the back of the decoder or to the brown wire which as far as I can make out is -V
http://www.zimo.at/web2010/documents/MX ... ers_EN.pdf page7
"Makeshift ground terminal if required between the diodes and the capacitor"
Re: Zimo MX600R
Thanks chaps, all useful information, hopefully I wont need to add a stay alive but if I do I can decide whether to try my hand at the soldering or use a different decoder.
