Hornby TTS decoders
HuskySteve
Hornby TTS decoders
Postby HuskySteve » Fri Nov 20, 2020 12:04 pm
Hi Guys, Has anyone had problems with Hornby TTS decoders?
I have two Un-Rebuilt Merchant Navy class models by Hornby and have fitted both with TTS decoders, one of them I hardwired and that failed after about a dozen times running, the second I hardwired an 8-pin socked to before installing the decoder. This morning I went to do some running on my layout after few weeks of not running, spent time cleaning the track and then began running some of my stock. The second Merchant Navy failed to start, even after cleaning the wheels and checking the wiring. It's a real shame because for a budget sound decoder, they were quite good.
Any advice/comments would be gratefully received. Steve :)
P.S Have re-posted in the correct section, DCC
MOD NOTE: Post moved to DCC section and the second identical post removed.
Life is not a rehersal
Re: Hornby TTS decoders
Postby Flashbang » Fri Nov 20, 2020 1:49 pm
Can you advise if these locos are older models that use Ringfield tender drives or are they modern Can motor versions?
If Ringfield motors the TTS decoder is not up to power them, as it has limited motor current of just 1/2 Amp (500 milliamp).
HuskySteve
Postby HuskySteve » Fri Nov 20, 2020 10:06 pm
Hi Flashbang,
They're modern can motors but are not fitted with decoder sockets.
RAF96
Postby RAF96 » Sat Nov 21, 2020 12:02 pm
You should do a motor stall current test on DC with the decoder disconnected to determine a suitable spec decoder.
RAF Halton Brat - 96th Entry
β-tester
HuskySteve
Postby HuskySteve » Mon Nov 23, 2020 5:42 pm
Thanks RAF96, will do that and maybe that's the answer.
