Lenz Digital Plus LS150 not accepting programming
Tiddles
Postby Tiddles » Mon Jan 20, 2020 10:18 pm
I think I may have buggerd it :roll:
It was working OK with the Lenz TR100/UK powering it.
But I tried it with an Hornby wall transformer that I use to power my analogue operated PECO points.
It worked for a little wile then stopped, so I reconnected it to the TR100. The light comes on when the button is pressed but it will not operate the point motors or accept programming or reset to factory settings.
I took the cover off and can not see any damage!!!
Re: Lenz Digital Plus LS150 not accepting programming
Postby Bigmet » Tue Jan 21, 2020 8:53 am
If it is less than 10 years from purchase, Lenz' warranty will cover it.
A&H Models are the UK distributor and can advise. https://www.aandhmodels.co.uk/
Tiddles
Postby Tiddles » Tue Jan 21, 2020 1:49 pm
Probably no warranties as I get it second hand on a eBay layout I purchased.
RFS
Postby RFS » Tue Jan 21, 2020 3:22 pm
Did the Hornby transformer supply DC power rather than AC? According to the manual this can damage it.
You can pick up SH LS150s off Ebay quite cheaply these days - around £25-30 or so.
Robert Smith
Tiddles
Postby Tiddles » Wed Jan 22, 2020 10:42 am
The transformer is AC 16v as supplied with the Hornby train set controllers.
I cut the end off and fitted a connector block.
Will look on eBay.
