4amp alternative for Select controller
669cpb
Postby 669cpb » Sat Feb 23, 2019 7:19 pm
Hi,
Will this power supply be ok to use with Hornby Select controller?
https://www.ebay.co.uk/itm/15V-4A-PA337 ... :rk:4:pf:0
Many thanks
Ironduke
Re: 4amp alternative for Select controller
Postby Ironduke » Sat Feb 23, 2019 8:58 pm
I think probably yes but you might have trouble matching the size of the centre pin on the Hornby select connector. To be on the safe side I would buy one with a range of removable connectors.
https://www.amazon.co.uk/s?ie=UTF8&fiel ... ex=blended
RAF96
Postby RAF96 » Sat Feb 23, 2019 10:45 pm
I am sure that 6.3 x 3mm plug is the same as Hornby kit. As long as the positive is on the pin and not the sleeve.
RAF Halton Brat - 96th Entry
β-tester
669cpb
Postby 669cpb » Sun Feb 24, 2019 7:33 am
Thanks for replies.
At least I have options that are cheaper than the Hornby one.
kebang
Postby kebang » Mon Feb 25, 2019 1:55 am
When I was using a select I purchase a cheap unbranded 4.5amp power supply for it. The select continued to operate perfectly until I purchased an NCE years later.
