New Z21 app update
Dr Diesel
New Z21 app update
Postby Dr Diesel » Thu Jan 31, 2019 10:48 pm
Hello all
The now available app update can help us out to remove the point numbers
Yet retain the route information which would also be removed before this update.
However a bit of typing is involved.
In control station delete all the route information out of the discription box, and replace with the new note box that can now be created. Slide it into position under the route Y circle, type the description of the route then size it up using the slide bar.
Now when you turn off the point numbers in the settings for the app,you will still have your route info showing as a note.
Jeff
