Tonight I decided to add a decoder to my Bachmann 43XX all was going well
to start with, drilled a couple of holes at the front of the tender floor wrapped
the tender weight with masking tape fed the wires through the holes to mate
up with wires from the loco. I split the chassis down carefully putting all parts
on white paper. Slightly filed to open the sprung motor contact housings. Used
spare decoder wires cut off the loom soldered on the motor tags then protected
by pushing on some fine plastic tube.
The chassis wires are to be held under the rear chassis fixing - And the usual
thing happened - the plastic fixing had the square head break off !! The other is
probably just as brittle, but not been tightened yet !
Now I have a stripped down loco that will have to lay around for the best part of
a week while I try to find replacement parts.
Thought I had one from an earlier job where the same thing happened, but an
hour searching all sorts of dark corners has failed to reveal my spare that should
be in a bag with a few black axle muffs ........... Thinking Was it 3 years ago ?
Geoff T
