nce powercab
finch
nce powercab
Postby finch » Sun Jun 05, 2011 2:29 pm
Hi there i have just bought the nce powercab,its all set up working fine,except locos seem to run slow, i want to run locos at a realistic speed,but my class 43 hst,s run to slow ,and some locos crawl at top speeds.Even running one loco ,it runs slow,do i need more voltage to the track,the transformer is 12v,does the nce boosters help at all,any suggestions would be great.
cheers Nidge
poliss
Re: nce powercab
Postby poliss » Sun Jun 05, 2011 2:38 pm
Would need to see a video before knowing if your locos are going slower than they should.
The booster is for the ammount of locos you have. It does not boost the speed of locos. I suggest you read the PowerCab manual thoroughly.
What is the model of your transformer and did it come as part of the package from a shop?
Class 37
Re: nce powercab
Postby Class 37 » Mon Jun 06, 2011 11:21 am
Hi,
When you say your loco's run slow. Are you compairing the speed to running previously on DC? If you are then it should just be a CV that will need altered in your decoder.
Mark
Class 37
BromsMods
Re: nce powercab
Postby BromsMods » Mon Jun 06, 2011 5:13 pm
I suggest you consider changing the decoders you have. I think we have already spoken about this on the phone and, since you can't change the CV values in the Hornby decoders, a change of decoder is my recommendation - try TCS as they usually work reliably and have full control.
finch
Re: nce powercab
Postby finch » Mon Jun 06, 2011 6:58 pm
Hi there i have found the problem,i have been sent the wrong power pack with the powercab,it should be a 13.8 voltage 2amps ,the one i have is 12 volts 1.5 amp,the shop have said they are speaking to nce ,they checked there new stock and found the wrong transformers had been supplied.Problem solved .
cheers Nidge.
Silver Surfer
Re: nce powercab
Postby Silver Surfer » Tue Jul 12, 2011 8:34 am
finch wrote:Problem solved ............
You hope!!!! :lol:
Have you tried it with a 13.8v/2amp unit yet? Let us know when you have.
Do as John suggests and change the decoders or you may still be disappointed...
Hawkers Bridge - A work in progress
__________________________________
'A Diesel engine is a machine - A Steam engine is a living being, almost human'
joshing_man
Re: nce powercab
Postby joshing_man » Thu Jul 14, 2011 11:22 pm
Has the updated version been released yet/ If not, does anyone know when it is now due?
Andrew
poliss
Re: nce powercab
Postby poliss » Fri Jul 15, 2011 12:56 am
Last I heard in February was, "The PowerPro upgrade will be delayed and is now likely to be June/July."
