LENZ MINI
locoworks
LENZ MINI
Postby locoworks » Tue Nov 02, 2010 4:30 pm
just recieved a few decoders with my new class 14 farish loco. ( very nice and fitting a decoder is going to be quite easy ) anyway i open the new lenz mini boxs ( when did lenz go cheap and put decoders in card boxes?? what happened to the useful clear plastic boxes? cheapskates ) and the decoders are smaller than the lenz mini i have on the shelf?? i have had a few of them so i do know the new one with wires, and the 6 pin new one are smaller. anybody know when this change took place?? i don't think the vendor has updated the new sizes on their website and if folks ( like me ) were going off just size alone they could be losing sales??
Essex2Visuvesi
Re: LENZ MINI
Postby Essex2Visuvesi » Tue Nov 02, 2010 4:55 pm
What size are they now? I found the Digitrax DZ125 to be the smallest so far
Proud member of the OAM
m8internet
Re: LENZ MINI
Postby m8internet » Tue Nov 02, 2010 4:59 pm
There are two Lenz Mini; Silver and Gold
The Silver is about the same size as the DZ125 / 36-558
The Gold is larger as it also has additional soldering points for the PSU
As for the packaging, would you rather have a 5% price increase or them swapping the packaging and retaining the same price
Personally, it does not bother me as the packaging goes into the bin once the item is over 6 months old
I retain the instructions, unless they are available in an online format
Equally, I may dispose of the instructions in due course and scan all of these
locoworks
Re: LENZ MINI
Postby locoworks » Tue Nov 02, 2010 6:38 pm
Essex2Visuvesi wrote:What size are they now? I found the Digitrax DZ125 to be the smallest so far
my old lenz mini which is 6 pin 651 plug in type ( which was ordered as silver and arrived in packaging badged as silver ) measured in roundish numbers ( ignoring the plastic insulation on the pins, just the PCB ) is 11 x 9 x 2.8 mm, the new ones ( silver again and again just the PCB size measurements) are 11.7 x 7.5 x 2.4 mm. so a bit on the length ( maybe an issue for dapol tenders?? ) but thinner in width and depth. the extra thinness allows it to fit in the bonnet width of the new farish class 14, but due to the thickness i will use a CT elektronics DCX75 which is about the same footprint, fits in the bonnet width, but is single sided and around 1mm thinner. the smallest i have used is the CT elektronics DCX74zD. have a google, but they are hard to come by and around double the cost ( so were the mini's ) of a DZ125.
Essex2Visuvesi
Re: LENZ MINI
Postby Essex2Visuvesi » Wed Nov 03, 2010 8:30 am
the DCX74zD is only €89.00 here :lol:
locoworks
Re: LENZ MINI
Postby locoworks » Wed Nov 03, 2010 8:45 am
Essex2Visuvesi wrote:the DCX74zD is only €89.00 here :lol:
how much!! where?? thats over £75!!!! are you having a laugh? i got two of them for about £70 about a year ago. you could get 4 DZ125's for that? :shock:
Essex2Visuvesi
Re: LENZ MINI
Postby Essex2Visuvesi » Wed Nov 03, 2010 11:09 am
yep that's what they are in my local model shop
I get my decoders from DCC supplies
locoworks
Re: LENZ MINI
Postby locoworks » Wed Nov 03, 2010 4:59 pm
Essex2Visuvesi wrote:yep that's what they are in my local model shop
thats where i just got mine from, but i didn't see a 64 for 75 quid!! it is priced the same as the 75's i just looked.
Essex2Visuvesi
Re: LENZ MINI
Postby Essex2Visuvesi » Wed Nov 03, 2010 5:51 pm
Sorry my last post was a little ambiguous.... My local model shop in Finland sells the DCX74zD for €89 so I buy DZ125's from DCC supplies
locoworks
Re: LENZ MINI
Postby locoworks » Wed Nov 03, 2010 11:35 pm
the fog lifts and things become clear. :D
BananaRepublic
Re: LENZ MINI
Postby BananaRepublic » Wed Nov 10, 2010 10:08 am
Back to the OP.
Just a thought.
The change in size of the Silver Mini 's may reflect the change over to the new "Plus" range introduced last year (2009).
The Silver Mini was replaced by the Silver Mini + at that time. All the dimensions, for both old and new models, can be found on the Lenz websites.
locoworks
Re: LENZ MINI
Postby locoworks » Wed Nov 10, 2010 10:32 am
BananaRepublic wrote:Back to the OP.
Just a thought.
that will be it then, but it seems some vendors have not ammended their websites to show the new dimensions.
