another attempt at downloading?
Post anything here to do with Model Railway Photography
rejrob
Re: another attempt at downloading?
Postby rejrob » Fri Sep 21, 2012 7:21 pm
B/B 34083 which was often on the Arrow Front of baggage van just shewing is a faded re TRIANG BAGGAGE VAN OFTEN USED AT THIS TIME
YARD SCENE WITH SIR HARRY NEXT TO A SCRUFFY N class There are 3 on the shed 31410/12 ;31826 The 1st 2 have been altered to left hand drive as originals Quite easy to do Bachmann loco.s
EFE RT,s meeting .RT191 based at Sidcup for quite a while with RT190 and another on route 229
Albert square as never before?Drunk in charge of a horse and the phantom flasher on the seat
a dusty jelly mould A30 Austin and a late night ice cream man
some general scenes you might find interesting
rejrob
Postby rejrob » Fri Sep 21, 2012 8:00 pm
further view of RT,s route 229 using RT,s from Sidcup(SP) and Bexleyheath(I think BX)
Overhead view of grubby 31558 which was at 73A
Before the layout was changed 4Sub 4107 entering the terminal and 34021 Dartmoor pulling out at lower level
2 of the A1X class In the book dealing with these lovely loco,s it gives the mpression that 32670 was not lined out in 1958 hence the easy paint job
variations on a theme?? :
destination of country area buses RT on route 401(Last one often run for in courting days??) and GS often used when visiting an uncles farm near Riverhead GS garaged at DG(Dunton Green)RT at Swanley
D
Bushey Troughs
Postby Bushey Troughs » Fri Sep 21, 2012 8:48 pm
Ron, I had hoped I would never see a 229 bus again. If you post a picture with an LT red 51 route, or a slam door with a 55 code. I shall be very upset. :lol:
I hate to be reminded of our time in Bexley. Nostalgia is not what it used to be.
OK, neat work keep posting the pictures. :wink:
COLIN.
rejrob
Postby rejrob » Sat Sep 22, 2012 6:59 am
Hi Bushey, As it happens :lol: :lol: :lol: ??I,ll save them for when you are not looking.Think the 51 was green street green to Sidcup until they lowered the road under the railway bridge in Station road sidcup The d/d turned round there except 1 RT that had its roof off by going forward instead of back ?There are some more I have found but the picci,s of the real thing will have to wait til I have Mastered(THats a laugh)scanning from the printer to Comp,Something not quite right All the best Ron
OZ tea called Bush (Bushy) is great.My son in Oz keeps me supplied
rejrob
Postby rejrob » Sat Sep 22, 2012 9:59 pm
'carry your cases sir" Pullman of the arrer with square windows Bloke totally fed up(Just been told his train cancelled??0 All the platform tops were made from 2 layers of Kellogs boxes cut to shape after the platform edging had been secured Lyers glued together then fitted to top of platform They were the correct thickness to fit in the rebated chanel in PECO edging
RF(garageTB) on route 227 with son on his BSA.C11
Sidcup RT on route 21 enroute to Farningham Sons garage in the background with triumph Herald jacked up on tyres Health and safety,forget it?
unrebuilt 34077(73A) hauling maunsell stock.All the Bulleid,s had their identities altered using modelmaster or;albert goodall etched names and badges
Revamped Bulleid 34003 Plymouth (73B)before layout was altered
yes there are more>Hope you like? :D
rejrob
Postby rejrob » Thu Nov 22, 2012 7:39 pm
With regard the #Bullet nose 4 sub (4315) the dock shunt motor trid but I have now fitted Tenshoda 35mm to either MTB. I did have to change the wheels as they were low profile??? and used romford 14mm instead which also included removing the axle cog and putting on the romford axle with a spot of superduper glue :D Goes well Shortly putting a couple more pictures on including DS74 Now the plumbing is finished a little more room to fit five EMU,s sidings and shed and washing unit Does anyone know of a firm that makes the older type of washer which is slightly ifferent to the modern Bachmann one.All the best with modelling
rejrob
Postby rejrob » Thu Dec 13, 2012 9:05 am
Hi all :D :D :D Talk about being premature :( New boiler and tank and shower and now only a six lane E.M.U shed plus hopefully a further siding .I am using a mixture of Metcalfe shed leftovers and wills asbestos sheets from 2 photos in books of emu sheds(Slade Green and Peckham)Having never been inside such a shed can anyone tell me please if the 3rd rail is still proud of what would be floor level and if here are mean of isolating individual rails within the shed Hopefully within the next 2 weeks should have some more picci,s All the best Ron
rejrob
Postby rejrob » Sun Jan 06, 2013 2:51 pm
early days on the layout Lefthand Nclass(Easy to convert Bachmann)
MTK prototype Wt 3 1/2lbsThick brass but accurate
SRG 4 Sub #Sheba4107
An early start Plenty of Modroc
lets go :D :D
rejrob
Postby rejrob » Sun Jan 06, 2013 3:21 pm
battledown flyover before being positioned
Interior of Cannon Street Stn
early days with the Wrenn Brighton Belle which ran beautifully and sounded like a real EMU
SRG #Nelson unit on upper level
MMM??
rejrob
Postby rejrob » Mon Jan 21, 2013 7:52 am
inside EMU shed 3ft 6ins long
4 lane EMUshed with scratchbuilt walkway,metcalfe and wills kit bits Metcalfe are very helpful should you want extra pieces
and the last
another view
DS74 extra weight needed .Used lead sheet under roof and in tool boxes so inconspicuous
Hi all,Yet another addition to a #Busy# layout As my hopes of replacing the tanks in the loft were dashed and my E.M.Us. seem to be multiplying,I removed a cabinet and was originally hoping for a 6 lane EMU shed .Because of the very limited space ,the radius capable of being used was insufficient so a 4 lane shed was made using Metcalfe engine shed parts,wills corrugated asbestos and scratch built walkway board and drain pipes 2 workshops were united into one and 2 wills workshop kits used to create a small #Scene# Taking the plunge I have again used the 3rd rail(Sausage fingers are not good for fitting rail chairs?? :D ) Ballasting as before using Avia bird grit and roads using sharp sand, the latter mixed with watered down PVA.I do PVA the places where ballasting occurs and clean up the track afterwards This part of the layout is nearly finished and I have managed to gain 1 extra siding for my 8 carCEP/BEP and one for the #Eastleigh crane Point work has been drastically altered to get round the lack of space When th rest of the parts needed arrive from the retailers(Sundeala;track etc)Snow stopped play I will add to these couple of picci,s.Also completed DS74 from Judith Edge.As mentioned elsewhere very finite limits All the best Ron
rejrob
Postby rejrob » Mon Jan 21, 2013 12:11 pm
Cannon St.again with Wrenn Brighton Belle and Leader in foreground shortly to be repainted into grey
Early scene The W.D. was posted to 73B in early fiftees but moved before 1958 To keep it allowed too much License?? The Bullion voach was one of 3 at the time I converted a Mk1 using drawings from the S,R,G Although it is Western based I have a photo behind a Waterloo bound West Country??
Interpretation of Cannon St. to suit my purposes
Corgi L.T. tree lopper
Hi, Just a few shewing the layout as was .Many alterations since these.Its been in existence since 1993
OliverSR
Postby OliverSR » Mon Jan 21, 2013 3:50 pm
Great photos as always.
Could you give some more info regarding the camel-back style loco as I have never seen anything like it before.
I am always interested in the southern, obscure and interesting locos and rolling stock.
OliverSR
rejrob
Postby rejrob » Mon Jan 21, 2013 6:17 pm
Hi Oliver, Thanks for the comment.I take it you mean D.S. 74.I stand to be corrected but I believe it was initially #Down the drain#(Waterloo and City. It then went ,I believe Durnsford Road Power station and did shunting of coal wagons.This station supplied the Southern with juice. When they started taking leccy from the grid it was scrapped The Judith Edge kit is good,very light hence he ballast and runs well >like you I like the unusual or irregular southern motive power including 7 different pushme pullyou,s :D :D LSWR;LBSCR etc all about in 1958 All the best Ron
rejrob
Postby rejrob » Thu Mar 28, 2013 5:52 pm
differt aspect Note the limited area
shewing part front of shed
EFE vehicles Frizzi lights giving gas effect (Poor lighting
nearly there
Wills interior
Hi all,Since my last import,due to the number of E.M.U.s on the layout further tracks were needed to act as sidings.Very limited area ,as you will see.I installed a number of added points.On Youtube shewing the Brighton Belle,is a glimpse of 3052 going through a carriage washing hut.I have tried to replicate this using wills asbestos corrugated sheet ,3 bottlecleaning brushes ,cut in half and trimmed and placed in the washing shed.To replicate water ,I painted the ground black and brushed gloss varnish on the area around the rails.I used a peco inspection pit,purely to get the rail chairs appearing as the video, and cut a strip of black plasticard which fitted on top of the chairs and between them for the length of the shed RSJ,s formed the skeleton of the shed ,all painted black and water pipes made using brass rod,similarly painted black and rust??The 4 lane EMU shed is 41ins long,this being made from adapted Metcalfe shed kits,wills corrugated asbestos roofing and a walkway fom plasticard the Ladder and protector rails were .45 brass wire soldered.The workshop are which shews replacement lathes and other workshop tools is a wills kit as is the interior of the signal box .Both buildings are lit by a single12V ex berko light. The Yard lights are a make I have not used before RMLectronics and the foremost #street lights in the yard are from Frizzi,s The yard lights are LED and very well made hope you like :D :D :D
rejrob
Postby rejrob » Thu Mar 28, 2013 5:57 pm
attachment]
more additions
more added points 72 on the layout
workshop area
signal box adapted
just a few more
part of the re-worked point system
Return to “Model Railway Photography”
