My personal layout under endless (re)construction
Daniel
Re: My personal layout under endless (re)construction
Post by Daniel »
Ex-Pat wrote:Surely you've a use for that lemon?
Which lemon?
My new Flickr:
https://www.flickr.com/photos/158027525@N08/
My old Flickr:
https://www.flickr.com/photos/daniel_1_32_scale/page223
Being right is one thing, but being true is quite another.
Daniel
Post by Daniel »
ImageIMG_0085 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0086 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0087 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0089 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0090 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0091 (2) by Daniel Osvaldo Caso, on Flickr
I am very tired now so I owe you the bla-bla until tomorrow.
Daniel
My new Flickr:
My old Flickr:
Daniel
Post by Daniel »
This is going to be a bit of a small very old village for mainly hidding a bit the right corner. It's name seems is going to be "Thermostat-Sur-Mer" and the reasons are obvious...
ImageIMG_0025 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0024 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0026 (2) by Daniel Osvaldo Caso, on Flickr
(The many holes in the 50mm foam are traces of it's long story...)
ImageIMG_0027 (2) by Daniel Osvaldo Caso, on Flickr
WARNING: there is, again, not such a thing as a 'plan'.
The footprint of the terrain was drawn long ago with I can't recall what idea but when I saw it again it was new to my lobe brain cell's poor elastic memory and I like it 'again'.
The idea it contains is to suggest a street behind the buildings at the front but that would be just suggested speculating with the fact that the place, position and distance from the front of the layout won't permit that the viewer's eye noitice the stree is just a couple of centimeters 'long' in both directions. Once I get there with the building, a couple of tricks will help to accentuate that effect...
ImageIMG_0028 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0029 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0030 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0031 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0032 (2) by Daniel Osvaldo Caso, on Flickr
The pencils in next photo are for showing the directions of the holes are not only inclined but all in different ...
ImageIMG_0033 (2) by Daniel Osvaldo Caso, on Flickr
No, the holes in one block doesn't neet to fit the ones in the other bloc...
ImageIMG_0034 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0035 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0037 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0040 (2) by Daniel Osvaldo Caso, on Flickr
The long 'pins' are a temporary way to hold under some pressure the joint until the silicone kit has set.
ImageIMG_0042 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0043 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0044 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0045 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0047 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0048 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0049 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0050 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0051 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0052 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0053 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0054 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0056 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0058 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0059 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0060 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0061 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0062 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0063 (2) by Daniel Osvaldo Caso, on Flickr
... so here a bit of a view of "Thermostat-Sur-Mer"...
ImageIMG_0057 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0065 (2) by Daniel Osvaldo Caso, on Flickr
Well, that was done yesterday. Later more on what is being done today.
Daniel
My new Flickr:
My old Flickr:
Daniel
Post by Daniel »
... but life goes on so...
ImageIMG_0001 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0002 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0003 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0004 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0005 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0006 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0007 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0015 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0016 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0017 (2) by Daniel Osvaldo Caso, on Flickr
The stones have been modified because where o.k. for 1/32 but too big for helping creating an atmospheric perspective effect...
ImageIMG_0018 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0019 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0020 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0021 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0023 (2) by Daniel Osvaldo Caso, on Flickr
The colors are coming up o.k. but the whole still will get a serious blending session once the building process is done and also a whitening veil (toguether with the surrounding landscape) so to help creating the effect of perspective...
but there is plenty to do before that!
More later.
Daniel
My new Flickr:
My old Flickr:
captrees
Post by captrees »
Great stuff Daniel. Love your work.
Daniel
Post by Daniel »
Thank you Captrees.
Good to know you enjoy it.
Feed back remains essential for the Muses so I'l let them know. :)
Daniel
My new Flickr:
My old Flickr:
Post by Bufferstop »
That thermostat needs replacing with a nice new wireless one, that you can reposition. I once worked with a guy who's decision to buy his housing association home was driven by their refusal to allow him to move a thermostat which got a blast of cold air every time someone went in or out of the rear door!
Daniel
Post by Daniel »
Bufferstop wrote:That thermostat needs replacing with a nice new wireless one, that you can reposition. I once worked with a guy who's decision to buy his housing association home was driven by their refusal to allow him to move a thermostat which got a blast of cold air every time someone went in or out of the rear door!
Well, thank you for the warning and the well-intentioned tip but, for this time, I won't tell the folks at Thermostat-Sur-Mer that you propose depriving them of their collective identity. And you should be very thankful for that because -I asume you didn't know- one of their attachments to tradition is the use of the guillotine (temporarilly hidden in the cellar of the second building from right.) :lol: :lol: :lol:
Daniel
My new Flickr:
My old Flickr:
Daniel
Post by Daniel »
... and today...
ImageIMG_0093 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0094 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0097 (2) by Daniel Osvaldo Caso, on Flickr
The little black ball under the arch is the head of a long pin holding it until the silcone kit sets. (That building is not glued in place yet.)
ImageIMG_0098 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0099 (2) by Daniel Osvaldo Caso, on Flickr
Next image show I miscalculated something so now the left end of the small street is visible if one stretch the neck from the front... (Is the white wall at the left end.)
I ImageIMG_0102 (2) by Daniel Osvaldo Caso, on Flickr
I was almost ready to start thinking (not really) when one of the Muses said:
"_No , no, no! Do need to think or sauch things: go find the rests of plastic mirror you have in some of the drawers and enjoy._"
I wanted the effect in next image so a couple of details (to come) would show the rear half of a small cart and some other thing as a dog walking under it so to suggest a kind of corridor but now I am going to see what the mirror suggest this time. (I have used such mirrors a couple of times in a diorama and are a nice trick to fool the eye.)
ImageIMG_0103 (2) by Daniel Osvaldo Caso, on Flickr
Daniel.
My new Flickr:
My old Flickr:
BrightonMan
Post by BrightonMan »
That is superb. Top work Daniel
Daniel
Post by Daniel »
BrightonMan wrote:That is superb. Top work Daniel
Thank you.
Good to know you like it.
Actually I am still enjoying a lot seeing how the village develops itself.
That's one of the beautiful things of doing not knowing what until it's done. :)
Daniel
My new Flickr:
My old Flickr:
Daniel
Post by Daniel »
... and here the last of today's:
ImageIMG_0104 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0106 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0107 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0108 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0110 (2) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0111 (2) by Daniel Osvaldo Caso, on Flickr
All other are glued in place already but not the one left in the photo.
Before I glue that one many things must happen but may be tomorrow gets done.
Daniel
My new Flickr:
My old Flickr:
Daniel
Post by Daniel »
Of course, those building need roofs...
...and, once more, I made a casting in common plaster and this morning was ready to me cut to shape and all the rest...
The silicone rubber mold was made using a commercial resin casting from MK-35 that is since already many years no more in production.
You probably have seen many roofs in my buildings with such a roof. (Not the one in the Valkenburg Diorama which was built with hand made tiles.)
I was ready to start cutting the new casting when something so0mewhere in what seems to be the big space in my empty head said:
"_Ting!_"
I saw only a plastic bag from the supermarket...
I asked: _What do you mean?_
But the only thing left was curiosity so I wanted to take a look and see...
Well, this is what I saw:
ImageIMG_0008 (2) by Daniel Osvaldo Caso, on Flickr
OF COURSE...!!!
That is a bag full of the old wallpaper of probably a room or home being redecorated which I found in the trash a dozen years ago or so...
By then I had found this images
ImageP2210975 (2) by Daniel Osvaldo Caso, on Flickr
... and thought it was rough slate or so... but it wasn't:
ImageP2150484 (2) by Daniel Osvaldo Caso, on Flickr
I love those stone roofs and tried to model some with materials from MNHS (Mother Nature Hobby Shop, a place where I get the best materials even when I have noi cents)...
ImageP2230231 (2) by Daniel Osvaldo Caso, on Flickr
ImageP2230232 (2) by Daniel Osvaldo Caso, on Flickr
ImageP2230233 (2) by Daniel Osvaldo Caso, on Flickr
ImageP2230234 (2) by Daniel Osvaldo Caso, on Flickr
ImageP2230235 (2) by Daniel Osvaldo Caso, on Flickr
ImageP2230238 (2) by Daniel Osvaldo Caso, on Flickr
ImageP2230239 (2) by Daniel Osvaldo Caso, on Flickr
and this was what I've got...
ImageP2230240 (2) by Daniel Osvaldo Caso, on Flickr
ImageP2230242 (2) by Daniel Osvaldo Caso, on Flickr
I liked it and used for a couple os small roofs in "Pondézar" and other build but such kind of bark is easy to find. Most have much thicker 'layers' or are too small... I will get back to that one day, as I find another conbvenient bark. The one above I brought from Nauders (Austria) twenty years ago.
But the old wallpaper wanted to tell me something so I listened...
It said:
ImageP2100787 (2) by Daniel Osvaldo Caso, on Flickr
ImageP2100788 (2) by Daniel Osvaldo Caso, on Flickr
ImageP2100789 (2) by Daniel Osvaldo Caso, on Flickr
ImageP2100790 (2) by Daniel Osvaldo Caso, on Flickr
ImageP2100791 (2) by Daniel Osvaldo Caso, on Flickr
ImageP2100792 (2) by Daniel Osvaldo Caso, on Flickr
ImageP2100794 (2) by Daniel Osvaldo Caso, on Flickr
ImageP2100795 (2) by Daniel Osvaldo Caso, on Flickr
ImageP2100800 (2) by Daniel Osvaldo Caso, on Flickr
ImageP2100801 (2) by Daniel Osvaldo Caso, on Flickr
ImageP2100802 (2) by Daniel Osvaldo Caso, on Flickr
ImageP2100806 (2) by Daniel Osvaldo Caso, on Flickr
ImageP2100825 (2) by Daniel Osvaldo Caso, on Flickr
ImageP2100827 (2) by Daniel Osvaldo Caso, on Flickr
ImageP2100836 (2) by Daniel Osvaldo Caso, on Flickr
ImageP2100844 (2) by Daniel Osvaldo Caso, on Flickr
ImageP2100846 (2) by Daniel Osvaldo Caso, on Flickr
Recently, no idea how many years later, when I was working on my ungoing diorama (not the layout) I considered recycling two pieces of that old try and may be you remember...
ImageIMG_0013 (2) by Daniel Osvaldo Caso, on Flickr
... but for adapting it I was forced to create a seam...
ImageIMG_0012 (2) by Daniel Osvaldo Caso, on Flickr
and that didn't conviced me so I thought I will get back to it later and now here I am, ready for playing with the old wallpaper...
I know, the real stones look twice as thick and for slate these are too rough...
So I tried this today...
Here you see a piece of the original and the sanded one:
No. It doesn't convince me for slate. But I want it as stone.
An unavoidable experiment will be, soon: two or may be even three layers of wall paper glued on each other with wallpaper glue and see if it works.
Actually there must be two experiments: one with plain wallpaper and one with latex painted one...
Well, for the time being I will go ahead whith what I already have but those experiment will BE and SOON.
Daniel
My new Flickr:
My old Flickr:
Daniel
Post by Daniel »
Yes, China inkt.
ImageIMG_0036 (2) by Daniel Osvaldo Caso, on Flickr
...dry pastel...
ImageIMG_0038 (2) by Daniel Osvaldo Caso, on Flickr
Yes, just rugged on the still a bit humid inkt...
ImageIMG_0039 (2) by Daniel Osvaldo Caso, on Flickr
Why?
No idea. Just didn't want to wait until it dries.
... but now I like a lot the ashen tone it gave...
ImageIMG_0041 (2) by Daniel Osvaldo Caso, on Flickr
Well, it can happen. The roof I was making was not the piece of Balsa wood cut for the roof but the remain of the cutting! :roll:
... so here we go again...
... because I assume after so many years the weighjt of the stoneroof must have affected the wooden frame...
ImageIMG_0055 (2) by Daniel Osvaldo Caso, on Flickr
More on this later. Now something else...
Daniel
My new Flickr:
My old Flickr:
