Montfort's Bridge
Montfort
Montfort's Bridge
Postby Montfort » Thu Nov 08, 2018 3:35 pm
Hello Happy Railway Modellers !
The Montfort's Bridge layout is on its way. First thing first, I built the baseboard. In fact it's a little bit bigger (4' x 10") than the original Barber's Bridge (22" x 8"). All your comments and avices are welcome. Thanks.
Back on the track !
Re: Montfort's Bridge
Postby Mountain » Thu Nov 08, 2018 3:38 pm
It's a nice start. It should fit in a car for easy transportation.
alex3410
Postby alex3410 » Thu Nov 08, 2018 4:04 pm
Good luck , i am looking forward to seeing how it develops :D
glencairn
Postby glencairn » Thu Nov 08, 2018 4:28 pm
See it from both sides. :lol:
Seriously. The hardest part is starting. 'Down hill all the way now'.
Well done.
Montfort
Postby Montfort » Thu Nov 08, 2018 5:07 pm
Thanks for your comments. A drawing to explain what I'm trying to build (hope that helps):
Back on the track !
Montfort
Postby Montfort » Thu Nov 08, 2018 8:59 pm
And now, back to work ! :lol:
BACK TO WORK.jpg (63.46 KiB) Viewed 718 times
Back on the track !
luckymucklebackit
Postby luckymucklebackit » Fri Nov 09, 2018 9:59 am
Bet that guy got the point :D
Montfort
Postby Montfort » Fri Nov 09, 2018 10:24 am
:lol: :lol: :lol:
Back on the track !
Postby Mountain » Fri Nov 09, 2018 11:16 am
They really lifted narrow gauge track like that. Ex WW1 narrow gauge trqck was specifically built like a trainset so it could be lifted and bolted together. Some is embedded in concrete and is down Pembrey Country Park in Wales. It was made from sections like that and used with the old Royal Ordinance Factory which was once down there. Mind you, it may have taken more then one man to lift each track section?
Montfort
Postby Montfort » Fri Nov 09, 2018 4:30 pm
This picture is just a joke. Nothing else. And WW1 is the biggest blood bath of the human being history. :evil:
Back on the track !
Montfort
Postby Montfort » Fri Nov 09, 2018 4:36 pm
I made a few scenery tries. I'm not very satisfied with the result.
Back on the track !
Montfort
Postby Montfort » Fri Nov 09, 2018 5:51 pm
I dumped all that junk in the trash can. I don't have the skills to build this layout. End of the story. Sorry for this waste of time. :oops:
Back on the track !
Postby End2end » Fri Nov 09, 2018 6:16 pm
Seems ok to me.
The only thing I'd change from that last shot is to use the cobbled sheeting inside the tracks and raise it and the surrounding cobblestones to track height so it looks like the track is sunk into them.
You could use multiple factory sheets layered together to give the building a little depth on the face. :idea:
roganty
Postby roganty » Fri Nov 09, 2018 7:57 pm
Montfort wrote:I dumped all that junk in the trash can. I don't have the skills to build this layout. End of the story. Sorry for this waste of time. :oops:
No one has any skills when they start a layout, it is the process that builds the skills.
So far all of your layouts have gotten no further than sticking some track to a board.
I had high hopes for this one. (For one, your baseboard looked professionally made)
I think that you should sit down with yourself and properly decide what you want to achieve.
For a first timer it doesn't have to be photo realistic and historically accurate, just something fun that you will enjoy.
If I were you I would persevere with this one. Print off more factory buildings from the internet, and not worry that the tracks are on top of the cobbles.
Remember: Rule number one.
Postby Mountain » Fri Nov 09, 2018 8:24 pm
Relax Montfort. You have some excellent ideas and plans. Take your time. Think of it as a marathon rather then a sprint. Do a bit at a time. Dont rush. Have a plan of attack. :) You can do it!
Try things you have not tried before. I think you will enjoy it. A hint. Not everything goes right. You need things to go wrong to teach you what does work well, so dont worry when things dont go to plan. It is part of the learning.
The little scene you made looked good to me.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 7 guests
