Staverton Junction
Samuel19
Staverton Junction
Postby Samuel19 » Fri Oct 26, 2018 12:56 pm
Hi,
Welcome to Staverton Junction.It is a GWR themed railway in a fictional location with a Branch line, Harbour, Narrow guage and a turntable.Pictures will follow later:
Samuel19
Re: Staverton Junction
Postby Samuel19 » Fri Oct 26, 2018 1:31 pm
Here are some photos:
Samuel19
Postby Samuel19 » Fri Oct 26, 2018 1:33 pm
And more: :)
Postby End2end » Fri Oct 26, 2018 1:48 pm
Hi Samuel19 and welcome to the forum. :)
Great looking turntable!
Samuel19
Postby Samuel19 » Fri Oct 26, 2018 2:03 pm
Thanks end2end.It was actually my older brother that made and painted the turntable as he used to work on (and still does ).It's know turned into a joint project! :D
Montfort
Postby Montfort » Fri Oct 26, 2018 3:22 pm
Good start. Thanks for the photos. I don't see any roof insulation. Am I right ? You're attic must be cold at this moment. :o
Back on the track !
Samuel19
Postby Samuel19 » Fri Oct 26, 2018 3:25 pm
Yh! It is. depending upon how hot the day is it might warm up in the middle of the day :D
BuffyMcBuffer
Postby BuffyMcBuffer » Fri Oct 26, 2018 7:41 pm
what are your trains running like at the moment with no insulation??
Just been up with little man and mine have dead zones because of the weather as before it got cold it ran fine
Samuel19
Postby Samuel19 » Fri Oct 26, 2018 9:53 pm
Hi!
The trains run fine without the insulation but there are some places where it's patchy but I think it more because of wiring/laying issues than anything else as is the same when it's warm.(I was trying them in this evening) :)
Hope you manage to sort out your insulation problems!
Samuel19
Samuel19
Postby Samuel19 » Fri Oct 26, 2018 10:05 pm
Quick progress update:
I went up in the loft this evening and finished of building the walls of the roundhouse,tested the inner and outer mainline track with 'The Lancer' and a GWR Pannier tank.Everything is working fine
Chops
Postby Chops » Sat Oct 27, 2018 7:55 am
That traverse from the inner to outer loop is quite nifty.
Nessie rocks!
Samuel19
Postby Samuel19 » Sat Oct 27, 2018 8:03 am
Thanks!
It was actually my older brother that laid the track but know its turned into a joint project as he doesn't have the time to do much anymore and he's away a fair bit of the time
Samuel19
Postby Samuel19 » Mon Oct 29, 2018 3:18 pm
It's half term this week so I'm hoping to get a fair bit more done!
Here is a list:
Finish of roofing for roundhouse
start planning an overall roof Branch line terminus
Start building the Branch line terminus
+if time and resources
Start laying Branch line track
Start building a small village
Quite a list for a week! :D
Samuel19
joshv8
Postby joshv8 » Tue Oct 30, 2018 9:36 am
Samuel19 wrote:It's half term this week so I'm hoping to get a fair bit more done!
Here is a list:
Samuel19
Thats a lot to accomplish in a week! I look foward to your progress photos
Samuel19
Postby Samuel19 » Tue Oct 30, 2018 10:07 am
Hi,
I'm hoping to get at least the first three things done it not more!but also if n here are too many visitors I might only get the first 2 done! :) I've already got a rough idea about the Branch line (Ashburton) and planning and measurements are fully underway!For the roundhouse roof i m thinking of using plasticard or printable texture sheets.The branch line station might need some greycard which I've run out ! I think a trip to the model shop might be needed :D and
Pictures will probably come tomorrow or thursday!
Samuel19
