Mumbles Southern Garage Layout II
Re: Southern Garage Layout II
Postby mumbles » Tue Nov 21, 2017 9:17 am
Bufferstop wrote:It does make some jobs a bit harder but having the track near to eye level definitely improves the view. I have a draughtsman's chair that puts me back to the same height as standing, but I usually end up standing often with a handheld controller in each hand.
Yes, saves ones back from crouching down to eye level.. We all do it!!! Once I get this set up for DCC I have plug in points for the controller at both ends... As seen when m.levin came down with his lovely sound locos. I think I've convinced my girlfriend that i can get a new laptop too for PC control 8) (it will have non train uses too :mrgreen: )
Postby mumbles » Tue Nov 21, 2017 10:27 am
I made a video following a train from fiddle yard and back again to try to show an overview
Youtubey linky
Lee
Postby Lee » Wed Nov 22, 2017 6:00 pm
mumbles wrote:I made a video following a train from fiddle yard and back again to try to show an overview
Youtubey linky
Great vid Mumbles, i love how you done the inclines like that work really well 8) :wink:
My N Gauge Layout.
Postby mumbles » Wed Nov 22, 2017 6:59 pm
Youtubey linky
Cheers Lee, the hidden bit is working better than the incline bit :lol: i expected some teething troubles to iron out though so all in my stride. It was why I made what i did with a 'can it be altered factor'. I think im going to move the fiddle yard a little further back and raise is by a few cms. Will make the inclines longer and more gradual with not much woodwork to do so.
I made another video, trying to show how a goods service runs up from folkestone towards sandling junction. As it does it passes the down passenger on its way to Folkestone, before it then returns with a parcel/passenger service... All was going really well...
Clicky Clicky
Postby mumbles » Wed Nov 22, 2017 8:10 pm
mumbles wrote:
Youtubey linky
Clicky Clicky
Edited because i got the order of trains wrong!
Postby Dave » Wed Nov 22, 2017 9:03 pm
mumbles wrote:Edited because i got the order of trains wrong!
You just cannot get the staff these days :lol:
Postby End2end » Wed Nov 22, 2017 10:48 pm
That organic rerailing tool looks a bit out of scale. :shock: :lol:
I wonder if those coaches are too light? I usually add some lead flashing to rolling stock to give them a bit of weight.
Hope it helps.
Lee
Postby Lee » Thu Nov 23, 2017 10:21 am
The hand of god moment as made my day :lol: :lol: :lol: :lol: nice video as usual 8)
My N Gauge Layout.
Postby mumbles » Fri Nov 24, 2017 9:39 am
End2end wrote:That organic rerailing tool looks a bit out of scale. :shock: :lol:
Hope it helps.
I think the coaches are fine, it was the points and excess speed!
Postby mumbles » Mon Nov 27, 2017 6:14 pm
I've been making some permanent supports for the inclines. I had some bolts not being used so made them adjustable for setting the final gradient more accurately. I'm in the process of going round the whole layout fixing in the supports and have also moved the fiddle yard further back to help add a little length to the gradients and to make the tracks to it in a better location in reference to those above.
Fiddle yard further back towards the rear
Lower access line moved back, same for the other end
Postby m.levin » Mon Nov 27, 2017 8:13 pm
I like your adjustable gradient idea.
Postby mumbles » Tue Nov 28, 2017 5:47 pm
m.levin wrote:I like your adjustable gradient idea.
cheers. It will certainly help getting it all the same gradient
Postby mumbles » Thu Nov 30, 2017 12:55 pm
Heres a nice little tip I only just learnt which you might find useful? Masking tape along the cut line when using a jigsaw stops the splintering you get with ply 8)
Postby mumbles » Thu Nov 30, 2017 6:17 pm
Well I'll carry on talking to myself :lol:
I've got the new track beds for the inclines cut and in place and I'm gradually making all the adjustable supports. For now I've kept the fiddle yard at the same height as before and can raise it if required. I'm hoping the longer gradients are enough to get them working better. At the 1:50 gradient I've been working at, it should be able to drop at least 16cm on each length of incline.
This is the workbench end, you can just see the coach on the now much further back entrance to the fiddle yard. I've also been adding bracing to the top level to make sure it stays flat and true. Plenty more of that to do but obviously has to avoid any points, so I've marked out where they will all be
At the other end the entrance to the fiddle yard is also further back adding length to the gradients. Im not far away from getting the rest of the track laid so i can see if the alterations have been successful
Postby Dave » Thu Nov 30, 2017 6:42 pm
mumbles wrote:Well I'll carry on talking to myself :lol:
Speak up, I have my earplugs in :lol:
