Mumbles Southern Garage Layout II
carnehan
Re: Southern Garage Layout II
Postby carnehan » Sun Nov 12, 2017 8:28 pm
Wow, great work on the inclines Mumbles. My heart was in my mouth as it trundled up and down without an ounce of protection should something go awry!
Postby mumbles » Sun Nov 12, 2017 9:12 pm
Dave wrote:I have been working my little socks off all weekend, but do not seem to have achieved a fraction of what you have. I take my hat off to you 8)
Your wood work is a work of precision compared to mine though!
Postby mumbles » Mon Nov 13, 2017 12:10 pm
I really should be more careful when i message m.levin and make sure i am not sending this to my other half!! :o
Tried to style it out!!
Postby TimberSurf » Mon Nov 13, 2017 12:18 pm
I interpret that as a Roman number
So her indoors has sanctioned the purchase of ten Loco's! :D
Postby mumbles » Mon Nov 13, 2017 4:03 pm
I've made a card mock up of one of the bridges ill be building. Crucially to check clearance. You can see that by this point the lower level is much lower than the low scenic point, and how from underneath you have access to all the line.
The real bridge/tunnel
Mock up showing scenic level. About 15cm?+/- above base frame units.. The hidden hatch!!
Postby mumbles » Mon Nov 13, 2017 4:14 pm
TimberSurf wrote:I interpret that as a Roman number
There will be no agreement.. Just a resignation that I'll do it anyway!! She ignored the message!!
Postby mumbles » Mon Nov 13, 2017 5:50 pm
More mocks ups!! On the left horn street will come from under the arch, the pub (there has to be a pub) will be on the corner which the road comes round and turns off again under the bridge up the hill to the station and goods yard of sandgate
This is the bit i rushed last time. I worked all this out after track was down last time. Taking a very different approach this time by making sure what I want fits before things are too fixed
Postby m.levin » Mon Nov 13, 2017 9:40 pm
Your banking seems very flat, they tend to be quite uneven.
Postby mumbles » Tue Nov 14, 2017 5:42 pm
I got the last of the track beds for all the hidden lines cut and in place. All the supports for the inclines can all still be changed to get the gradient right and I could still raise the fiddle yard higher if needed. Was about to give it a coat of grey primer and realised I had the wrong paint. Too light and a solvent based which will take ages to dry!!
Over view
Work bench area with raised programming track 8)
Postby mumbles » Tue Nov 14, 2017 7:12 pm
Having got that much done it frustrated me having the wrong paint. So I nipped out and got it and have lavished it in a lovely coat of grey primer
Lee
Postby Lee » Tue Nov 14, 2017 7:38 pm
Nice work i love seeing this stage of the layout, this is the where the magic starts 8)
My N Gauge Layout.
manna
Postby manna » Tue Nov 14, 2017 7:49 pm
G'Day Gents
Looking forward to seeing where all the track goes, looks like Egyptian scaffolding at the moment. :D
manna
Postby mumbles » Tue Nov 14, 2017 8:30 pm
manna wrote:G'Day Gents
manna
On the grey bits :lol:
On a serious note.. Yes, it is on stilts!!! It is this height that gives the hidden lines accessibility while the scenic areas are at eye level when sitting down. The front lowest frame of the scenic zone will be about 5" above the base unit.. Plenty of arm room to reach under to the hidden lines without crawling.. Front access!
Its worth pointing out that i still have a lot of frame work to add for strength and reinforcement. The beauty doing it this way is i know where point motors need to be so can fit supports around that. I've got the track bed roughly where i want it and I can make it all much sturdier as I become sure gradients, track position and other factors are known.
This is chair height
Stool height
Postby mumbles » Wed Nov 15, 2017 2:39 am
Managed to get a little track down in the fiddle yard, and then got sidetracked making sure my control panel and DC power supply worked.. It does. I can drive trains with either control with the flick of a switch 8)
This picture shows how the top track level can just be unscrewed and lifted off to work on the fiddle yard. I've tried to design the structure so its as easy to work on as possible. The plan being to get all the lower levels running and wired up and the i can work on the top levels
Postby mumbles » Wed Nov 15, 2017 7:58 pm
I have got the basic track in the hidden storage down. I have room to add a few more points, but they will be used on the top for now.
The programming track is crying out for a little single track diorama on a shelf
