Kerluk's layout
Re: Kerluk's layout
Postby Mountain » Sun Feb 05, 2017 6:40 pm
Yes, that is the traditional track cleaning rubber. Been using them for years. Bother Peco and Hornby make them. I use both.. Whichever I can find... So for now it is my Hornby one.
The track cleaning rubbers are a gentle abrasive which rubs dirt off the track surface. There are other methods of cleaning track, though I've always used the rubbers myself as they are relatively cheap and last a long time. Expect 2 to 10 years use depending on how large your layout is and how often you use it.
Kerluk
Re: Kerluk's layout
Postby Kerluk » Sun Feb 05, 2017 6:47 pm
Emettman wrote:That's nice running. Can I ask what controller you're using?
Yes you can ! It's a homemade controller with a DPDT center off toggle switch: :oops:
Re: Kerluk's layout
Postby Mountain » Sun Feb 05, 2017 6:49 pm
You don't have to press too hard in use as I often find a light pressure but quick movement does just as good.
Re: Kerluk's layout
Postby Mountain » Sun Feb 05, 2017 6:50 pm
Which bit on the wiring diagram is the overload cut out?
Is it the component next to the 15v thingie.. Near the potentiometer thing..
Kerluk
Re: Kerluk's layout
Postby Kerluk » Sun Feb 05, 2017 6:54 pm
It's not on the wiring diagram. I use a car bulb (12v / 21w). It's a very old trick... :o
Re: Kerluk's layout
Postby Mountain » Sun Feb 05, 2017 6:56 pm
Ooh. Good idea.
Re: Kerluk's layout
Postby Bufferstop » Sun Feb 05, 2017 8:15 pm
That circuit is pretty much the same as the original Gaugemasters. You could install their GM41 thermal cutout into one of the leads between the transformer and the bridge rectifier. It will give better protection to the controller as well as the locos.
Kerluk
Re: Kerluk's layout
Postby Kerluk » Mon Feb 06, 2017 7:06 am
The wiring diagram updated:
Kerluk
Re: Kerluk's layout
Postby Kerluk » Mon Feb 06, 2017 8:00 am
My controller is as simple as that:
Kerluk
Re: Kerluk's layout
Postby Kerluk » Mon Feb 06, 2017 5:34 pm
A new passenger train arrived on Kerluk's layout :lol:
New passenger train
The video
Re: Kerluk's layout
Postby End2end » Mon Feb 06, 2017 6:50 pm
All aboard! :D
How about some lighting and passengers?
viewtopic.php?f=1&t=50754
Although for DCC track pick up I'm sure the circuit could be modified to DC power pick up.
Kerluk
Re: Kerluk's layout
Postby Kerluk » Tue Feb 07, 2017 8:35 am
Thanks End2end! :D
I have no problem with DCC because I'm a "DC guy" :lol:
Kerluk
Re: Kerluk's layout
Postby Kerluk » Thu Feb 09, 2017 4:09 pm
Once again I changed my track plan :oops: :roll: :o
I used my own "power clip" and I'm very happy with the result :D
New track plan
My own power clip
Kerluk
Re: Kerluk's layout
Postby Kerluk » Thu Feb 09, 2017 4:11 pm
The rush hour at Kerluk's Layout :lol:
The rush hour
alex3410
Re: Kerluk's layout
Postby alex3410 » Thu Feb 09, 2017 4:14 pm
Kerluk wrote: I'm very happy with the result
It looks much better! can hardly see it, good job :D
