The Harz In HOm
Austinw
The Harz In HOm
Postby Austinw » Wed Jan 11, 2017 5:02 pm
A few photos from my Harz based layout in HOm scale. I've partially completed the station platforms and the engine shed area. As there is no freight traffic now in the Harz, the Faller goods shed has had some heavy weathering, as will the track on which it stands as I want to represent a disused shed on an overgrown siding.
vs170124-010 (Copy).jpg (56.97 KiB) Viewed 832 times
vs170124-008 (Copy).jpg (60.92 KiB) Viewed 832 times
vs170124-006 (Copy).jpg (43.81 KiB) Viewed 832 times
vs170124-002 (Copy).jpg (70.93 KiB) Viewed 832 times
vs170124-001 (Copy).jpg (51.01 KiB) Viewed 832 times
Austinw
Re: The Harz In HOm
Postby Austinw » Sun Feb 12, 2017 8:21 pm
Here is a link to a video of the layout showing some further progress;
https://www.youtube.com/watch?v=GHYdgAkGiHA
Re: The Harz In HOm
Postby b308 » Mon Feb 13, 2017 9:27 am
Very nice Austin... Are you going to exhibit it?
You may want to join NGRM Forum, there are several Harz modellers on there!
Re: The Harz In HOm
Postby Dad-1 » Mon Feb 13, 2017 11:13 am
Hi Austinw,
Very nice layout - end to end is what most of us have to
be content with.
I have no knowledge of the stock/environment feel/operating
so would never think of doing something like this. What I do
appreciate is something away from the British Outline norm.
Visually so refreshing.
Re: The Harz In HOm
Postby End2end » Mon Feb 13, 2017 12:44 pm
Absolutly charming. :) Nice to enjoy something other then British outline for a change and thanks for the video. Although a small layout you've really captured a sense of open space. That abandoned goods shed looks great!
Austinw
Re: The Harz In HOm
Postby Austinw » Tue Feb 14, 2017 6:19 pm
b308 wrote:Very nice Austin... Are you going to exhibit it?
Thank you, I definitely don't think I'm up to exhibition standards so it will only be seen on video! Appreciate the advice re the NGRM forum, I'll take a look
End2end wrote:Absolutly charming. :) Nice to enjoy something other then British outline for a change and thanks for the video. Although a small layout you've really captured a sense of open space. That abandoned goods shed looks great!
Thanks for your kind comments, once I add the forest section it will be better as it will give a decent run.
Dad-1 wrote:Hi Austinw,
be content with.
Thanks very much, I've come to love the Harz after a couple of visits and with Tillig producing locos and rolling stock I just had to have a try.
Austinw
Re: The Harz In HOm
Postby Austinw » Fri Jan 12, 2018 5:52 pm
Rather a long time since I last posted so I thought I'd do an update. Over the past year I've added little bits of scenery to the main board (6'x2') but the layout didn't have a permanent home until November last year when I was able to proceed with the next two baseboards. The first is 4'x1' and is a forest area which runs into a board 5'x1' containing a station and runround loop. The track is laid and ballasted on that board and electrics completed and amazingly it works once everything is connected. I've just completed the forest section so things hopefully look a little more 'Harz like'. Attached are several photos showing progress to date
Trees just planted, now they are cutting them down!
99 7238 makes its way through the forest
The abandoned goods shed
Overview of the station and asparagus stall
Showing the forest half planted
Re: The Harz In HOm
Postby TimberSurf » Fri Jan 12, 2018 7:47 pm
Wow, huge progress in a short time! Looks great.
The cut tree's are a nice touch.
Re: The Harz In HOm
Postby Mountain » Fri Jan 12, 2018 9:38 pm
What I love about your layout is that there is not too much track... It gives room for the scenic touch!
Austinw
Re: The Harz In HOm
Postby Austinw » Sat Jan 13, 2018 9:11 am
TimberSurf wrote:Wow, huge progress in a short time! Looks great.
Thank you, it's coming along now it has found a permanent home.
Austinw
Re: The Harz In HOm
Postby Austinw » Sat Jan 13, 2018 9:13 am
Mountain wrote:What I love about your layout is that there is not too much track... It gives room for the scenic touch!
I have to say that the scenic side of model railways is what I enjoy most and with relatively little space there just wasn't enough room for more track in this scale
Austinw
Re: The Harz In HOm
Postby Austinw » Mon Jan 15, 2018 8:00 pm
Short video showing progress on the layout to date;
https://www.youtube.com/watch?v=ydJDq6l4-bk
Users browsing this forum: Google [Bot] and 5 guests
