Wykeham - Somewhere in the South.
Re: Wykeham - Somewhere in the South.
G'Day Gents
Not in my early ex LNER ABC either (app 1951) J38, 65934, then jumps to class F2 67108. so a big jump with nothing in the 66xxx group.
manna
PS. Nice diesel.
manna
PS. Nice diesel.
I fitted my new Hornby Class 66 Capt. Tom Moore with the Hornby TTS sound decoder today. I replaced the Hornby speaker with a Zimo LS40x20x09 Optimised "3D" Speaker - 80hm - 1Watt. The speaker came from YouChoos - it took about ten minutes. It really does need lights?
This was straight out of the box - it would probably benefit from an hour on the rolling road.
Click on picture to hear sound.
Lighting kit is in the post.
IMG_0709 by Barry Clayton, on Flickr
Belisha beacons, taxi roof lights and street lights now working. I now need to add some lighting to the buildings - and may be the bus
Click on the picture for a short video. BB
IMG_0768 by Barry Clayton, on Flickr
Wonderful stuff, the lights looks fantastic. Maybe I'll be brave and add some to my next layout...
Cracking street scene
Many thanks for the comments. I have now added some interior lighting to the shops, however it needs toning down a little, and I have some interior backscenes that will add a little depth. The lighting circuit for the shops, taxi lamps and street lights is 12v switched through a voltage regulator (dimmer switch?), if the voltage is reduced to much, which is great for the shops, the belisha beacons stop flashing - so may need to add some sort of diffuser to each LED in the shops - still thinking about that one. Also thinking about lights in the bus!! BB
IMG_0775 by Barry Clayton, on Flickr
- RailwayRobbo
The lighting is excellent. Very effective.
Thanks Pete - Fitting the lights has been a bit of a fiddle, it really is a job to be done when constructing the buildings. I used some very small pre-wired LED's that came on a small paxoline plate with a built in resistor - so hooking up to a 12v supply was no problem. I used two strips of copper tape along the ground floor of each building and soldered the LED's to the tape. A pair of wires soldered to the tape drop down through the board, where I have an "L" shaped 12v dedicated "bus" made from copper rods - each arm is about eighteen inches long. Everything is attached to that. Each rod has suitably spaced red or black heat shrink so as I don't solder anything to the wrong rod. All seems to work ok - the power runs through a voltage regulator switch - so I can turn the brilliance down. BarryRailwayRobbo wrote:The lighting is excellent. Very effective.
- BrightonMan
I'm in the process of wiring up the lighting for my station. It is a fiddly job but well worth the effort I think. Yours looks great.
It is worth it in the end BrightonMan - just takes a bit of time.
Here's a picture inside the good shed.
IMG_0777 by Barry Clayton, on Flickr
I managed to get some lights into the bus - fiddly job, probably would not do again.
IMG_0801 by Barry Clayton, on Flickr
Oooooops! Double entry. Mods. can delete. Thanks you.
