Cheadle Bay - N Gauge in the round
McScooby
Postby McScooby » Fri Apr 29, 2016 9:24 pm
As per my planning thread, here http://www.newrailwaymodellers.co.uk/Forums/viewtopic.php?f=44&t=49738 I've actually started work on the layout today. I've picked up a new toy to help build the board.
My new toy: -
Board built: -
Under side: -
Supervisor: -
Test laying of the track: -
My next job is to actually varnish the board and then I can start to do some testing of the plan itself.
42! What sort of answer is 42!
Re: Cheadle Bay - N Gauge in the round
Postby Emettman » Fri Apr 29, 2016 9:58 pm
Looks neat!
Odd thought: if the two inner sidings of each pair instead curved to make a loop, that could still be worked as a siding from either end, but allow extra movement possibilities, principally for freight.
Chris.
Kentishman
Postby Kentishman » Mon May 02, 2016 3:35 pm
You've made a good start there, nice woodwork.
McScooby
Postby McScooby » Fri May 06, 2016 9:16 pm
I've finally been able to get the board varnished, only taken 6 days. Damm thing called work. :x
The Woodland Scenic foam track bed I plan to use has been ordered and should be here in a week or so. My next job is to work out how I'm going to control the point son my layout, not sure if to use point motors or wire in tube.
Taking my son to Derby railway show at the weekend so will see what ideas I can find there.
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 18 guests
