GWR BRANCHLINE...EXE VALLEY
DAVE1562
Postby DAVE1562 » Thu Aug 23, 2012 5:49 pm
Hi all...further progress on my N gauge GWR themed branchline...it now has a name,Exe valley. i have made a few track changes from original plan to use a single hh gaugemaster with simulation brake and do away with a troublesome double crossover...kept on derailing stock.all track is still loose laid as yet.
i have nearly wired all mainloom but still have seep point motors to fit and wiring for streetlights etc,momentary point switches and isolation switches are wired and fitted, magnetic uncouplers are still yet to be sorted...heres a few pictures.......
EXE VALLEY 010.JPG (166.61 KiB) Viewed 7084 times
EXE VALLEY 012.JPG (167.11 KiB) Viewed 7084 times
EXE VALLEY 006.JPG (165.17 KiB) Viewed 7084 times
EXE VALLEY 005.JPG (178.38 KiB) Viewed 7084 times
EXE VALLEY 001.JPG (176.98 KiB) Viewed 7084 times
Essex2Visuvesi
Re: GWR BRANCHLINE
Postby Essex2Visuvesi » Thu Aug 23, 2012 6:12 pm
Thats some very neat wiring... mine always starts with the best of intentions but ends up looking like an explosion in a spagetti factory
Proud member of the OAM
DAVE1562
Re: GWR BRANCHLINE
Postby DAVE1562 » Thu Aug 23, 2012 6:26 pm
THANKS Essex2v...i hate untidy wiring...more pics
EXE VALLEY 003.JPG (165.88 KiB) Viewed 7072 times
EXE VALLEY 011.JPG (167.42 KiB) Viewed 7072 times
EXE VALLEY 009.JPG (167.44 KiB) Viewed 7072 times
DAVE1562
Re: GWR BRANCHLINE...EXE VALLEY
Postby DAVE1562 » Sat Aug 25, 2012 1:31 pm
Hi all....its raining again :roll: so i found somthing to occupy myself!!! finally fitted scenic back boards and will progress with more wiring,have ordered some seep pm1,s and made a bid on ebay for hh controller...hopefully another bargain :D
EXE VALLEY 003.JPG (168.12 KiB) Viewed 6972 times
EXE VALLEY 002.JPG (176.18 KiB) Viewed 6972 times
EXE VALLEY 001.JPG (177.32 KiB) Viewed 6972 times
rhiclin
Postby rhiclin » Tue Aug 28, 2012 11:01 am
Looking good. Very tidy. Looking forward to seeing more..
DAVE1562
Postby DAVE1562 » Sun Sep 23, 2012 6:24 pm
Hi all quick update on build... more wiring of seep point motors carried out and have ordered some more, removed the long loop so now it is a single line and reversed siding into main station which looks better it will allow me to add a engine shed and goods shed...had a go at a bit of hill making using newspaper and watered down pva..came out quite well but will cover with plasterbandage to make it more solid.i will turn the l/h corner into a tunnel when track is fixed down but at the moment having problems with noisy track so it will have to wait.Had a go at assembling some ratio platforms which look better than the metcalfe kit which i originally bought..it has more detail and character...
Got some bargains of ebay..h/h controller,dapol auto coach and a nice 57xx 0-6-0 tank loco,my wife has also bought me a dapol 14xx tank and autocoach for xmas but not allowed to have it!!! untill then :roll:
GWR BRANCH LIN...EXE VALLEY 002.JPG (175.25 KiB) Viewed 6687 times
GWR BRANCH LIN...EXE VALLEY 004.JPG (167.05 KiB) Viewed 6765 times
GWR BRANCH LIN...EXE VALLEY 003.JPG (168.05 KiB) Viewed 6765 times
GWR BRANCH LIN...EXE VALLEY 001.JPG (177.97 KiB) Viewed 6765 times
DAVE1562
Postby DAVE1562 » Sun Sep 23, 2012 6:26 pm
more pics.....
GWR BRANCH LIN...EXE VALLEY 008.JPG (171.16 KiB) Viewed 6686 times
GWR BRANCH LIN...EXE VALLEY 006.JPG (168.11 KiB) Viewed 6686 times
GWR BRANCH LIN...EXE VALLEY 007.JPG (167.87 KiB) Viewed 6764 times
DAVE1562
Postby DAVE1562 » Fri Oct 05, 2012 5:13 pm
A Bit more work on scenery building up the tunnel...needs a lid,made up some new point boards and finished fitting all seep pm1s to points..all works perfect now,solved track noise by fitting 1 mm thick neoprene foam(very fine closed cell) aquired of ebay :D i can now start ballasting and rail weathering... found a use for old coffee granules....ballast!! , superglued to balsa and then painted matt...looks quite good just needs weathering,got a new bargain...dapol gwr 45xx
EXE VALLEY 001.JPG (167.32 KiB) Viewed 6626 times
EXE VALLEY 005.JPG (170.7 KiB) Viewed 6626 times
EXE VALLEY 003.JPG (167.84 KiB) Viewed 6626 times
EXE VALLEY 004.JPG (169.08 KiB) Viewed 6626 times
EXE VALLEY 002.JPG (168.64 KiB) Viewed 6626 times
DAVE1562
Postby DAVE1562 » Mon Oct 29, 2012 11:12 am
Hi all ...more progress, ballasting nearly finished and ready for weathering,modroc applied to scenery and still in progress,unsure what method of rock face to use-cork,rock mold kit or sculpting plaster...any recommendations? a bit of kit building with a kestral goods shed and painting of platforms again just need weathering at some point,have ordered a ratio station and gwr station shed for main station and looking for something smaller for exe halt.
Exe main station looking outbound towards tunnel
EXE VALLEY 001.JPG (168.16 KiB) Viewed 6323 times
Tunnel entrance and goods sidings
EXE VALLEY 126.JPG (168.8 KiB) Viewed 6440 times
Exe sidings
EXE VALLEY 125.JPG (168.49 KiB) Viewed 6440 times
Exe main station
EXE VALLEY 127.JPG (168.01 KiB) Viewed 6440 times
DAVE1562
Postby DAVE1562 » Mon Oct 29, 2012 11:15 am
more pics...
Exe main looking outbound
EXE VALLEY 003.JPG (176.01 KiB) Viewed 6322 times
Exe halt
EXE VALLEY 124.JPG (167.95 KiB) Viewed 6439 times
nickbrad
Postby nickbrad » Mon Oct 29, 2012 5:47 pm
How big roughly is this? I almost wish I wasn't so against 'N' personally or I could plan for so much more than what I can fit in using 'OO'.
Great work btw, looking fantastic so far.
DAVE1562
Postby DAVE1562 » Mon Oct 29, 2012 6:15 pm
Hi nickbrad...the layout is in a u shape... 6ft x 6ft x 6ft and 1 ft wide 9mm mdf top boards covered in 2 mm cork and 9 inch high backboards,all come apart in 3 seperate tables if need be?...fits nice and snug in a spare area in the corridor,i chose n gauge due to space limitations and also like you said i could fit a lot in a small area. :D
Exe valley
EXE VALLEY 002.JPG (168.3 KiB) Viewed 6321 times
DAVE1562
Postby DAVE1562 » Tue Nov 06, 2012 5:23 pm
Hi all....been busy finishing tunnel and rock faces using modroc plastercloth..came out well,now ready for painting rock colour! weathered rails with sleeper grime and now looking better(used!!),still some tidying up on bits of ballast and weathering
EXE VALLEY 005.JPG (178.87 KiB) Viewed 6257 times
EXE VALLEY 003.JPG (177.18 KiB) Viewed 6257 times
EXE VALLEY 001.JPG (179.05 KiB) Viewed 6257 times
Michaelaface
Postby Michaelaface » Wed Nov 07, 2012 3:34 am
why has this received so few comments? this layout is looking really great will be following with interest!
Blue_2
Postby Blue_2 » Wed Nov 07, 2012 8:59 am
Looking good! You're getting on better with your tunnel/hill than I seem to be! :oops:
Users browsing this forum: Bing [Bot] and 8 guests
