Cheers Pete
seanhellen wrote:Hi,
The cobalts are great, the instructions that come with are vague to say the least, however the online instructions are superb and can be found here--> http://www.dccconcepts.com/PDF_Download ... manual.pdf
The instructions say to use sticky pads or the screws supplied to mount it but the pads I had (not supplied) werent really stick enough, but the screws were a pain to get in...well for me and my big hands anyways. Soooo, i ended up temp. fixing the motors with the pads, making sure they threw the points correctly then used a hot glue gun to hold the properly. Also the instructions say to remove the spring by taking the point apart but you can pull it out from under the point before you lay it
I know it soinds like a lot of work, but it is more than worth it in the end.
Electrical connections are easy too, theres 8 of them on the motor, just tin the ends and you can "poke" them
In the connection block - job done the 2 either end are for the motor (yep, just 2 wires) and the other 6 are for the 2 built in switches...you use 1 set for changin polarity of the point frog and I use the other switch for LED indication on the control panel...or I will when I get them
Essex2Visuvesi wrote:Guess you have one of these then?
http://en.wikipedia.org/wiki/Bridezillas
Users browsing this forum: Google [Bot] and 18 guests
