My N gauge layout
bbdave
My N gauge layout
Postby bbdave » Sat Aug 27, 2011 9:44 pm
Hi i started this a while ago it is proceeding steadily basicly i wanted a layout that has to be stored under the spare bed so not to high. I want a layout i can just run model trains on i'm not sticking to a particular era or area as i like to many things so it would be impossible to narrow it down but as i am new to all this maybe a era/area will come out of it and i'll eventualy stick to that but for now something to run on with some scenic to keep me occupied i have taken some pics so far.
002 (2).JPG (71.21 KiB) Viewed 1034 times
003 (3).JPG (69.91 KiB) Viewed 1035 times
002 (3).JPG (58.94 KiB) Viewed 1035 times
Re: My N gauge layout
Postby Lofty » Sat Aug 27, 2011 9:47 pm
Nice construction there Dave, what thickness of ply (I assume it is ply) have you used :?:
bbdave
Postby bbdave » Sat Aug 27, 2011 9:55 pm
The track is code 55 the curve radius is 15" to get the maximum run on the board all the underlay and track is copydex'd down which worked a treat i will be using DC and have wired each piece of track layed with 4 isolating sections operated by switches.
002 (4).JPG (68.22 KiB) Viewed 1010 times
004 (3).JPG (81.36 KiB) Viewed 1009 times
002 (5).JPG (84.62 KiB) Viewed 1008 times
003 (5).JPG (111.71 KiB) Viewed 1007 times
bbdave
Postby bbdave » Sat Aug 27, 2011 10:04 pm
I have taken some pics of the switch box which is re-movable so the board will roll under the bed without snagging
005 (3).JPG (48.72 KiB) Viewed 994 times
007 (2).JPG (56.67 KiB) Viewed 993 times
006 (2).JPG (52.46 KiB) Viewed 991 times
004 (4).JPG (55.56 KiB) Viewed 992 times
003 (6).JPG (60.49 KiB) Viewed 990 times
bbdave
Postby bbdave » Sat Aug 27, 2011 10:08 pm
Hi lofty the ply is 8mm for the framing with 6mm top it has a 9mm board diagonaly underneath to make the whole lot rigid in retrospect i should have made the framing half the depth i did to allow more head room under the bed therefore higher scenics could have been added.
Postby Lofty » Sun Aug 28, 2011 8:35 am
Cheers Dave,
Hindsight is a wonderful thing :D
bbdave
Postby bbdave » Sun Aug 28, 2011 10:06 pm
It certainly is. I'll Be getting the modrok on the bulk of the hill tonight another new experience but at least it's free :D
