Gateside and Northbridge - It begins at last!
manna
Re: Gateside and Northbridge (Incorporating the Allanshaw Inglenook)
Postby manna » Mon Jan 14, 2019 9:53 pm
G'Day Gents
That's coming along nicely. I do find plastic brick! to be better than brickpaper.
manna
Postby Mountain » Mon Jan 14, 2019 10:13 pm
That bridge looks ace.
Postby TimberSurf » Mon Jan 14, 2019 10:23 pm
Abutments look great, I am in the no paper brigade as well, next project is a multi arch stone bridge, I am currently messing about with embossing clay, but if it does not work out, I may resort back to linka and if that don't work, will end up with plastic! :lol:
luckymucklebackit
Postby luckymucklebackit » Tue Jan 15, 2019 11:10 am
Thanks everyone, the only issue I am finding is making sure I get a good outside edge, the second photograph shows what I mean as there is a distinct seam running down from the top of the pillar. I am going to experiment with some stiff Polyfilla before painting to try and avoid obvious gaps.
Cheers all
joshv8
Postby joshv8 » Tue Jan 15, 2019 11:24 am
Its really looking mint Jim. I think polyfilla should work for you. Might take a couple of wipes though!
Nice work as always mate
Postby TimberSurf » Tue Jan 15, 2019 12:34 pm
I am told that wood filler is good instead of the likes of milliput!
luckymucklebackit
Postby luckymucklebackit » Tue Jan 15, 2019 12:44 pm
TimberSurf wrote:I am told that wood filler is good instead of the likes of milliput!
Thanks Timbersurf, I will try that instead, think I have some somewhere :)
Ex-Pat
Postby Ex-Pat » Tue Jan 15, 2019 2:00 pm
luckymucklebackit wrote:Thanks everyone, the only issue I am finding is making sure I get a good outside edge, the second photograph shows what I mean as there is a distinct seam running down from the top of the pillar. I am going to experiment with some stiff Polyfilla before painting to try and avoid obvious gaps.
Cheers all
From memory I think that Geoff Taylor (in the Activity Media series) takes a needle file gently across the gaps and that tends to conceal them!
Ex-Pat
Postby Ex-Pat » Tue Jan 15, 2019 11:26 pm
Cheers all
Sorry Jim - memory malfunctioning! Took a look at the DVD, and what he does is to gently scrape the joint with the scalpel blade and then finish it off with fine sandpaper.
luckymucklebackit
Postby luckymucklebackit » Wed Jan 16, 2019 8:35 am
Ex-Pat wrote:
Cheers all
Yes Ex-Pat - thanks! One thing I quickly learned in this exercise is not to cut the plasticard too neatly before gluing in place, the first sheet stuck down needs to be about 1-2mm oversize then trimmed bang flush with the edge of the substrate when the glue is set, then similarly the second sheet at the angle needs to overhang very slightly so that a scrape and sandpaper brings it back to a neat 90deg join. The gap was the first sheet of plasticard applied before this lesson was learned so a bit of filler followed by some filing and sanding should do the job. :)
railwayjim
Postby railwayjim » Wed Jan 16, 2019 5:52 pm
The stonework supporting the bridge looks spot on Jim. Visually 3d using plastic.
A wipe with decorators caulk using fingers solves the gap problem for me and it's dry overnight.
Each to their own though.
Jim.
luckymucklebackit
Postby luckymucklebackit » Wed Jan 16, 2019 8:53 pm
railwayjim wrote:The stonework supporting the bridge looks spot on Jim. Visually 3d using plastic.
Jim.
Thanks Jim - Having seen your cracking buildings that sounds like another good alternative to try, I think I have a tube of caulk in the DIY box.
JIm
luckymucklebackit
Postby luckymucklebackit » Thu Jan 17, 2019 1:47 pm
Going forward fro the bridge build (getting ahead of myself a bit here as the bridge has a bit of work yet to do), the area under the bridge will be a (rather narrow) diorama depicting what used to be under the prototype at Parkhead Forge on which the Allenshaw bridge was based. This map shows that there were a number of tracks passed under the bridge, but in the period I remember it the two topmost tracks had been lifted, the next two were the main running lines (which still exist to this day) and the tracks below were still used but heavily overgrown, these were yard worked and served Parkhead forge.
We will see how it turns out!
joshv8
Postby joshv8 » Sat Jan 19, 2019 11:40 am
I'm excited. I really quite like the prototype there so Im looking foward to seeing how you approach it!
railwayjim
Postby railwayjim » Sat Jan 19, 2019 5:07 pm
Looks like your first job Jim ..... build a pylon :D
Cracking drawing to go off.
Jim.
