Gateside and Northbridge (Incorporating the Allanshaw Inglenook)
manna
Re: Gateside and Northbridge (Incorporating the Allanshaw Inglenook)
Postby manna » Mon Sep 24, 2018 4:33 am
G'Day Gents
I have a feeling the the shunting plank is going to get more use than the main layout !! :lol:
manna
luckymucklebackit
Postby luckymucklebackit » Tue Sep 25, 2018 8:26 am
Hi Manna - to your point, the shunting plank is a bit of an "insurance policy" against future possibilities that my mobility precludes me getting up into the loft, or having to move house due to health issues with either myself or Mrs LMB, that way I will always have a small layout to fall back on - two actually, as the St Margarets Depot extension was designed as a removable "plank" that could be adapted as a standalone (wonder if the two could go together NO STOP IT RIGHT THERE!!!!!! :D )
I bit the bullet last night and stripped out the plastic levers for the uncouplers, these are now all copper tube, the mechanisms were also cleaned out as the PVA mix and paint from ballasting had washed down inside the tubes and added friction, working fine now.
Away to Holland for the rest of the week so no more work until next week
Cheers everyone
manna
Postby manna » Tue Sep 25, 2018 9:05 pm
G'Day Gents
Good thinking Jim, I'm lucky, my layout is at ground level (part of a large shed) All I have to do is get down a (wheelchair access ramp) walk across the garden, and up one step, the wheelchair ramp, I built a couple of years ago, in case my back goes permanently, a bit of foresight can help in the long run :D
manna
Postby Mountain » Tue Sep 25, 2018 9:44 pm
That's actually a good plan. A friend of mine had retired. I used to work with him on the railway. He was building a nice layout in his attic. However in the past few years he was was less able to get to his attic and instead had to do armchair modelling. He enjoyed it but maybe a compact portable layout would be better for him as it would keep him happily modelling...
Trying to take over the world... HAHAHAHA!
luckymucklebackit
Postby luckymucklebackit » Mon Oct 01, 2018 9:29 pm
Back from what turned out to be an interesting trip to Holland. Once the work was done I headed back to Ede-Wageningen station for the train back to Amsterdam, highlight of that trip was this beauty which was being hauled towards the west
image removed due to Flickrs greed.
Anyway back to Allenshaw tonight and I finished off painting the track, a tedious but worthwhile task, I then gave the ballast a general coat of Railmatch Brown Paint
Some stock on the layout, this will be the "start point" for any puzzle, with the trip freight having arrived behind a Clayton which has uncoupled and moved into the loco siding and the shunter then drawing the train forward into the headshunt
There is a bit of a puzzle within a puzzle, in that the brake van is not part of the main Inglenook shunting puzzle, but still has to be at the back of the outgoing train, it is easily done once you work it out - any guesses??
Hopefully will get started with buildings on Friday!
Last edited by luckymucklebackit on Tue Nov 20, 2018 1:34 pm, edited 1 time in total.
Postby Mountain » Mon Oct 01, 2018 9:34 pm
I love the point levers. I assume they are point levers.
luckymucklebackit
Postby luckymucklebackit » Mon Oct 01, 2018 9:39 pm
Mountain wrote:I love the point levers. I assume they are point levers.
Nope - you have not been paying attention :D They are the lever mechanisms for the uncouplers that have been giving me all the grief, the all brass ones are the replacements for the plastic ones that snapped! The points are operated by the bicycle spokes that are tipped with the little lettered cubes.
Postby Mountain » Mon Oct 01, 2018 9:42 pm
Ah yes! :D it makes sense now. I love home made mechanical things.
Montfort
Postby Montfort » Tue Oct 02, 2018 6:04 am
Great work ! Congrats. That's what I call a real Shunting Layout.
Back on the track !
railwayjim
Postby railwayjim » Wed Oct 03, 2018 7:03 pm
Evening Jim,
I am trying to solve how the brake van is attached to the departing train.
But first could you explain how it was moved off the incoming train picture 2 and into the siding in picture 3 :?
Jim.
luckymucklebackit
Postby luckymucklebackit » Wed Oct 03, 2018 8:47 pm
railwayjim wrote:Evening Jim,
Jim.
Hi Jim - Without the bridge in place there was an element of "big hand from the sky" (for illustrative purposes only) :D But with the bridge in place it works like this, there are two possible solutions
The train loco detaches and runs forward into the loco siding, The shunter then draws the train forward and either:
1) The brake van is left at the nearest uncoupling ramp, then the train loco moves out and drags the van in past the points, then once the shunter has deposited the five wagons in the first siding it comes back and moves the van into the van road OR
2) (Simpler solution) The shunter drags the full train into the headshunt and the train loco follows it in, picks up the van then moves it to the van road!!
Must do a video someday!
railwayjim
Postby railwayjim » Wed Oct 03, 2018 9:13 pm
Think I've got it Jim, but yes, a video would be perfect.
Let me know when and I will get my tea and biscuits ready for the viewing :D
Jim.
luckymucklebackit
Postby luckymucklebackit » Fri Oct 05, 2018 9:06 pm
Hi All - with all the track painted and ballasted, time to start the buildings. First up is the Walthers crane gantry kit which turned out to be quite tricky, there are a lot of parts that you need to ensure are kept square and level, and it only takes the smallest sliver of flash to knock things out of true. I built up the main gantry and legs and the main parts of the crane, as you need this to gauge how far apart the rails need to be.
Also marked out the end of the building to check proportions
With all looking good, I removed the crane to safe storage to let the glue fully set before painting and gluing in place so that I could make a start on the loading bank, this is just built up from strips of wood and a sheet of ply, it has a couple of slots cut to tack the crane legs, these slots will be closed up when I put on the top sheet of card
The buffer stop is a modified Peco, as per the prototype in the photo I posted on Montfords thread, need to find another one, there is one somewhere in my scrap box I'm sure
That's all for now, looking out my "kiss me quick" hat as I am off to Sunny Blackpool next Friday!!!
Chops
Postby Chops » Mon Oct 08, 2018 10:55 am
Breathtaking in scope.
luckymucklebackit
Postby luckymucklebackit » Mon Oct 08, 2018 10:58 am
Chops wrote:Breathtaking in scope.
Cheers Chops - glad you like it! :D
Users browsing this forum: heda and 14 guests
